0 members (), 137 guests, and 2 robots.
Topics128,211
Posts1,057,475
Members48,473
#1613111 10/12/2026 3:40 PM
Is it safe to say if I install a 12 volt starter , 1954 261 engine, I must have a 168 tooth ring gear?
BarryP #1613113 10/12/2026 3:49 PM
Yes, if you install a 12 volt starter you MUST use a 168 tooth flywheel ring gear.
Look HERE for details.
I've had a 6 volt starter and flywheel on my converted to 12 volt electrics truck for over 40,000 miles.
BarryP #1613124 10/12/2026 5:38 PM
i've had a 6volt starter on my 12 volt car for over 40 years and probably 40-50 k miles work perfect.
Thanks J
Can I use the same flywheel, 13", And change to a 168 tooth ring?
BarryP #1613130 10/12/2026 6:26 PM
H Online: Content
I believe there's a different inside diameter ring gear between the 139 and 168 tooth gears. Just put 12V to the 6V starter and move on. If you want to have the resistor bypass terminal on the foot switch, just use the 12V switch. It's a bolt-on swap to the 6V starter.
