7 members (Shade Baby, Mike Burns, Gdads51, Bill Hanlon, 55shaker, crenwelge, klhansen), 171 guests, and 8 robots.
Topics128,241
Posts1,057,871
Members48,477
Hi all
Doing rear brakes on subject vehicle and trying to get drum off
Wheel cylinders leaking
The twist is that the rear end is out of a 70s C60
Can’t turn tires by hand so shoes adjusted too tight and adjusters frozen
This is the two wheel cylinder style any ideas?
What if it took wheel cylinder bolts out and tried to knock wheel cylinders in?
Scratch that
A stop and adjusters holding shoes out so loosening cylinders won’t help
Hate to stick a torch through adjuster hole to loosen adjusters
Have then soaking
See pics
Jack - Perhaps these YouTube videos can be of some help. They are for a '70's C60 and deal with the brakes on the rear axle, so maybe they will give you some light bulb flash ideas to tackle your problem. headscratch
Big Blue Brakes Part 1 - The Chevy C60 Wheel Cylinder Removal
Big Blue Brakes Part 3 - The Brake Job is Becoming a Battleground on the C60
There are two other videos but those mostly focus on other brake components, while these are specifically about the rear axle.
I partially watched the first one and it has a unique way of removing those wheel cylinders. wink
Let us know if these help. smile
~ Dan
1951 Chevy 3 window 3100
Thank you
I’ll check them out
Appreciate it
What if in addition to the wheel cylinder bolts you grind off the heads of the shoe retaining posts so that the shoes and everything else can slide off with the drums?
1949/50 3600 Project
Follow in Project Journals
I think that might be my only option
I’m going to soak a few more days
Trying Kroil for the first time
Always heard it was good…..
Update
Kroil is not a miracle product
Adjusters still wouldn’t move
Thought I’d remove the tires getting ready to cut shoe hold down pins
My 3/4” Chicago pneumatic impact would not break lug nuts loose so had to heat them
After that wheel spun freely
No clue what happened
Better to be lucky than good
Just barely got drum off with ridge but got it off
Thanks again
Crusty Old Sarge
Crusty Old Sarge
I have always used the Heat , Soak, Repeat method. Sometimes you do just get lucky..
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Victor Hot Wrench to the rescue- - - - - -once again!
7
7 Offline
Originally Posted by Jack Ryan
Update
Thanks again
With a 3/4 inch CP wrench, you ought to be able to dang near twist the bolts/studs. I use a 1/2" Ingersoll rated at 600 ft/lbs, but it won't give full torque until I remove the restrictive quick connect and attach the 3/8 hose directly to the wrench. Give that a try next time you really need the impact and torque. Torque spec for my Budd lugs/bolts is 500 ft/lb
