4 members (Jon G, pvfjr, cmayna, 1 invisible),
183
Mod | | | Forums66 Topics128,241 Posts1,057,871 Members48,477 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Hi all
Doing rear brakes on subject vehicle and trying to get drum off
Wheel cylinders leaking
The twist is that the rear end is out of a 70s C60
Can’t turn tires by hand so shoes adjusted too tight and adjusters frozen
This is the two wheel cylinder style any ideas?
What if it took wheel cylinder bolts out and tried to knock wheel cylinders in? | | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Scratch that
A stop and adjusters holding shoes out so loosening cylinders won’t help
Hate to stick a torch through adjuster hole to loosen adjusters
Have then soaking | | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | | | | | | Joined: Sep 2009 Posts: 6,119 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,119 | Jack - Perhaps these YouTube videos can be of some help. They are for a '70's C60 and deal with the brakes on the rear axle, so maybe they will give you some light bulb flash ideas to tackle your problem. Big Blue Brakes Part 1 - The Chevy C60 Wheel Cylinder RemovalBig Blue Brakes Part 3 - The Brake Job is Becoming a Battleground on the C60There are two other videos but those mostly focus on other brake components, while these are specifically about the rear axle. I partially watched the first one and it has a unique way of removing those wheel cylinders.  Let us know if these help.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Thank you
I’ll check them out
Appreciate it | | | | | Joined: Nov 2021 Posts: 1,426 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,426 | What if in addition to the wheel cylinder bolts you grind off the heads of the shoe retaining posts so that the shoes and everything else can slide off with the drums? | | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | I think that might be my only option
I’m going to soak a few more days
Trying Kroil for the first time
Always heard it was good…..
Thanks | | | | | Joined: May 2019 Posts: 238 'Bolter | | 'Bolter Joined: May 2019 Posts: 238 | Update
Kroil is not a miracle product
Adjusters still wouldn’t move
Thought I’d remove the tires getting ready to cut shoe hold down pins
My 3/4” Chicago pneumatic impact would not break lug nuts loose so had to heat them
After that wheel spun freely
No clue what happened
Better to be lucky than good
Just barely got drum off with ridge but got it off
Thanks again | | | | | Joined: Mar 2007 Posts: 3,481 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,481 | I have always used the Heat , Soak, Repeat method. Sometimes you do just get lucky..
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: Feb 2004 Posts: 29,909 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,909 | Victor Hot Wrench to the rescue- - - - - -once again! Jerry
| | | | | Joined: Feb 2016 Posts: 2,004 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 2,004 | Update
Thanks again With a 3/4 inch CP wrench, you ought to be able to dang near twist the bolts/studs. I use a 1/2" Ingersoll rated at 600 ft/lbs, but it won't give full torque until I remove the restrictive quick connect and attach the 3/8 hose directly to the wrench. Give that a try next time you really need the impact and torque. Torque spec for my Budd lugs/bolts is 500 ft/lb
