2 members (Peggy M, Pinetree), 81 guests, and 3 robots.
Topics128,232
Posts1,057,818
Members48,477
#1612486 10/03/2026 2:08 PM
Good morning!
So, I have a problem that I hope you all can help me with. I have a 1960 Chevy 235 truck engine in my new to me 1950 Chevy 3600 that I am working in bringing back to life. I found that the oil pickup tube screen had a hole in it so I will need to replace it. Where is a good place to find one? The parts stores are no help on this one. They all have the press in and the flange ones. Mine is threaded into the cast body of the pump.
53&Me #1612489 10/03/2026 2:53 PM
G'morning!
Hopefully a solution to your problem. wink The original part for your '60 235 is listed in the Chevy Master Parts Books as Group 1.656, GM# 3756605, Oil pump intake w/suction pipe. It is threaded into the oil pump and is listed as fitting all 1959-62 Chevy 235's.
There is an NOS GM# 3756605 currently offered on evilbay for what looks like a decent asking price. Look at the pictures in the ad. It shows the threaded end you need, so hopefully this can make your search short and sweet. wink
PS - I've moved your post to the Truck Parts Wanted forum as that's where it fits best. smile
~ Dan
1951 Chevy 3 window 3100
53&Me #1612502 10/03/2026 4:57 PM
Why not just replace the screen? I use stainless steel perforated metal that I buy on Ebay.
www.ebay.com/itm/157821810251?
All the screen has to do is strain out chunks big enough to damage the pump gears- - - - -everything else gets caught by the oil filter.
53&Me #1612503 10/03/2026 6:03 PM
My 1957 235 engine had the same. (Guessing sat in some moisture).
I tack welded S.S. screen on it. Good to go.
1950 Chevy 3100
53&Me #1612505 10/03/2026 6:39 PM
Or… you could buy the entire oil pump that I have listed in the parts for sale section. Just a suggestion. Reduced to a mere $25 plus shipping.
I invest my money in precious metals, mostly rust!
53&Me #1612540 10/04/2026 1:05 AM
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I had the same issue with my '60 235. I wasn't able to locate another OEM pickup tube either. I used the head from a V8 style pickup and sliver soldered a sleeve on it to fit the original tube.
There were no problems other than getting the original tube clean enough to take the solder.
235 Pickup Tube 2
Soldered Tube
Soldered Tube 2
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
53&Me #1613679 10/20/2026 4:13 PM
I'm scrapping a 235 if you need the oil pump.
