2 members (Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 7,012 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,012 | Why don't any modern coils fit in the original brackets?
You can expand the bracket with the long screw but then the two mounting holes won't line up with the mounting bolts on the pushrod cover. Is the bracket supposed to be offset and use only one mounting hole? If so, why did GM make the brackets with two mounting ears?
I also reamed out the oblong holes on each ear but when the bolts go into the engine, the bracket is stilk too tight for the coil.
I have several Delco Remy coils from the 1950s and they're all the same size and the mounting brackets are identical to each other.
How is the coil supposed to be mounted on a 1950 1/2 ton truck? Were original Chevrolet coils skinnier?
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2020 Posts: 1,985 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,985 | I ran into one recently that was Made in Mexico that worked still but only slightly larger than the new one. The bolt just being long enough. I`d think this would work...classicparts.com/chevy-gmc/truck-parts/1934-1946-truck-parts/engine/ignition-system/1941-76-ignition-coil-12-volt
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2004 Posts: 29,923 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | I've never had that problem, but if it's something you're encountering for some reason, just bolt a piece of aluminum bar stock to the head with flat head screws, and drill and tap the bar at the right spacing for the coil bracket holes. There's a huge amount of room "outside the box" for solving such situations! Jerry
| | | | | Joined: Jan 2014 Posts: 3,690 'Bolter | | 'Bolter Joined: Jan 2014 Posts: 3,690 | Why don't any modern coils fit in the original brackets?
How is the coil supposed to be mounted on a 1950 1/2 ton truck? Were original Chevrolet coils skinnier? This is a real thing. I have lived it on multiple engines now. Easy to overcome but still maddening that it’s even an issue in the first place. Not sure what is the actual root cause….but have to assume the original coils were very slightly skinnier.
1951 3100
| | | | | Joined: Oct 2021 Posts: 7,012 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,012 | Yeah I had to ream both oblong screw holes in the bracket ears a considerable amount just to get the holes to line up with the two mounting holes on the engine side cover.
And then it's still tight enough where it'll hold the coil in place without that long thin machine screw, which is good because after the bolts are in place you can't get the machine screw into its slot.
When the truck came to me it was only mounted with one bolt in the bracket and the other hole was left blank because there was no possible way to put the bolt through the ear and the side cover. And you couldn't just put a bolt in the side cover because then the mounting bracket wouldn't lie flat against the cover.
| | | | | Joined: Feb 2000 Posts: 5,260 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,260 | I run into this on restoring Pontiac engines, doesn't matter what years, the coils and brackets barely fit each other. | | | | | Joined: Feb 2004 Posts: 29,923 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | Those coils might have the same problem as truck owners- - - - -as they get older, they get bigger around the middle? LOL! Jerry
| | | | | Joined: Jan 2022 Posts: 121 'Bolter | | 'Bolter Joined: Jan 2022 Posts: 121 | Ran into that same problem on my '50 216. Methinks that the coils are made to the amazingly precise dimensions used in the Chinesium factories that furnish us with their sorry c**p. | | |
