5 members (BarryP, Mike B, ShopRag, Youngin' Tut 59, klhansen), 90 guests, and 2 robots.
Topics128,139
Posts1,056,756
Members48,454
Hey Everybody,
I need a new engine for my 1953 3100. I can use any of the listed inline engines. It has to be a running engine in usable condition. No rebuilds. I can travel a limited distance, but prefer an engine located within 100 miles of Fredericksburg, VA.
Thanks!
Mike
1953 3100
The Gray Ghost
My Project journal
I'll broaden the range to 150 miles from Fredericksburg, VA.
Mike
1953 3100
The Gray Ghost
My Project journal
Gray ghost I am in Stafford VA, and working on a 53 3100 as well, let me know if I can help!
Thanks, Buckeye!
Mike
1953 3100
The Gray Ghost
My Project journal
Mike - I did some web surfing for ads in your general vicinity. Only one FBM ad for a 235 within the 150 radius is listed 235 in Harpers Ferry, WV. It unfortunately doesn't indicate it is a known good running engine. Just mentions it "turns over freely". The casting code confirms it's a low water pump 1959 block, but no serial number to confirm further details.
I expanded my search to 250 miles, just to see if there was anything lurking farther out. These are the next ads currently listed, some saying running or removed from a running vehicle:
1957 running 235 from a car in Lebanon, PA
taken from a 1956 sedan - running 235 but smokes and needs rings in Sanford, NC
Chevy straight 6 235 - sitting for an unknown amount of time and will need work in New Tripoli, PA Note: pictures show a Dec 27th 1954 block casting date for casting code that match 1955-57 235's. Guessing this is a very early 1955 model year engine.
1954 Chevy 235 in used/good condition in Donora, PA Actually about 275 miles distant from you. Does say it was pulled to do a SBC swap, so maybe in running condition?
Sorry that there doesn't seem to be any better candidates than these, but perhaps one may work?
~ Dan
1951 Chevy 3 window 3100
24601
24601
Mike -- Have you talked to Chris Sweet about your search yet?
Frankly, I doubt you will find a good running engine you can plug and play. I learned the hard way that any unknown engine, running or not, needs to be considered a "Rebuildable Core." Yes, you might find one that runs okay. You may even get to see and hear it run. It won't even smoke. But it's only a matter of time (weeks/months) and you will be pulling it to rebuild anyway. So why play Stovebolt Roulette and end up paying good money for a "running engine" and then pay big money (and time) rebuilding it anyway?
A running, unrebuilt Stovebolt Six is an engine with a minimum of 6 decades under its belt. Who knows what's about to go belly up inside it? And who knows where that would happen. Sure would stink to have it happen on route 3 in front of the mall .... Its a much better candidate for a rebuild than it is for a drop in replacement.
Just sayin'
"Capn Sunshine"
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Well, I tried the guys on Lebanon and St. Tripoli in PA about a week ago. Neither responded. I thought they were good candidates for me but it didn't pan out. Hope you have better luck!
1954 3600 Stakebed
non-original engine out of a '55 passenger car with powerglide
I took one ride in John's truck after the 216 got swapped for a "recently rebuilt" 261- - - - - -and watched the oil pressure drop to dangerously low numbers, and listened to a very worrisome knock develop as it got up to running temperature. Dropping the oil pan just a few days later revealed a connecting rod bearing that was on the verge of making its way into low earth orbit! Fortunately, John was wise enough to treat my concerns seriously and avoid a disaster!
Hey Everybody,
I appreciate the help and wisdom! I had seen some of the listed engines and actually almost bought the one in Lebanon, PA. I ended up not buying it for a variety of reasons. The problem I've got is money. I don't have any for the machine shop. I've started fantasizing about a rebuild that didn't require a machinist.... Then I come back to reality. Maybe it's time to sell a few things to raise some money for a rebuild.
Mike
1953 3100
The Gray Ghost
My Project journal
That would be your best bet. There is no way to verify what condition a running engine is actually in that you buy from a stranger.
A good machinist familiar with Stovebolt engines who stands behind their work will give piece of mind which I consider priceless.
Other than some left over odds and ends, this is really all I've got that I could sell. Early on I had planned to use these parts. Now, I just want it to run so I can drive it and the single Carter seems to do a good job. Honestly, I think I'll ditch the fenton headers and go back to the factory exhaust manifold. Then I could sell the fentons, too. Is it worth the effort to sell these parts?
Mike
1953 3100
The Gray Ghost
My Project journal
Selling used engine parts is always a challenge as you need to find someone that is looking for what your selling and the buyer pool is not very deep. That being said any cash you can generate from the sales is better than parts sitting on the shelf. Listing parts here or Marketplace is not too daunting and free so at least you would not be loosing part of the proceeds to others.
1949/50 3600 Project
Follow in Project Journals
Those should help out in financing your rebuild and there should be an interest .Dont give them away. Check first what there value could bring.
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
Ad placed in parts for sale section. Lots of pics!
Mike
1953 3100
The Gray Ghost
My Project journal
