8 members (mason86, Ol'55, klhansen, Hotrod Lincoln, 32Fordpuchoptop, Ponchogl, Phak1, 1 invisible), 77 guests, and 1 robot.
Topics128,050
Posts1,055,676
#1611511 09/17/2026 5:20 AM
TeW
Offline
Where do I attach the chains on my 235 to remove from my 37 GM truck? Pictures would help.
TeW #1611512 09/17/2026 5:48 AM
H Online: Content
I remove the rocker arms and pushrods, and attach two short pieces of angle iron to the cylinder head with 3/8-16 grade 8 bolts. Then use a piece of 5/16" chain linked to the angle iron with clevises to lift the engine. Lift from slightly rear of center to account for the weight of the flywheel, clutch, and bell housing. If you remove the front sheet metal- - - - -fenders, hood, and radiator support, it's a LOT easier to pull the engine on that style of truck. That assembly can be removed all in one piece with a little forethought and a couple of strong-armed helpers.
TeW #1611515 09/17/2026 6:54 AM
If you have the rockers with studs that hold the valve cover on, you can use them as attaching points. I do that on my 216 with an engine leveler that I built from a trailer tongue jack. I pull and install the engine with the 3-speed transmission attached. Picture #1 shows that. I've use the same setup with the cab on as well (front clip removed. The 48-51 Truck Shop manual shows using a couple of eye bolts in place of a couple head bolts. Picture #2 is an excerpt from that manual. Pic #3 shows the eyebolts and lifting bracket from the special tool figure in the manual.
TeW #1611526 09/17/2026 2:28 PM
I used my cherry picker engine hoist to pull my front assembly when I pulled my engine. Used a old tow strap as the lifting sling.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
Brian Moore #1611544 09/17/2026 5:03 PM
Yep. A 2x4 spreader and a length of rope thru the brackets for the fender braces. Balances nicely there. Not familiar with the configuration of the earlier trucks, but I think the front clip could be manhandled off with 2-3 guys, as there's not a lot of weight there.
