Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (TUTS 59, Otto Skorzeny, Lostbuthaulinass, baldeagle, Phak1, Hambone, dunfire), 57 guests, and 1 robot.
Topics128,004
Posts1,055,246
Members48,418
1 bbl Rochestor carb. I have a fuel leak where the fuel line enters the carb. I have tried a small brass nipple and a brass MPT to barb fitting. Both of them leak. So the question is, is there anyway to seal this junction? Is there a pipe dope for gasoline or Thread tape. I know that there are possible issues with the sealant or tape fouling up the carb. I would still be interested in any possible solutions.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
I would try Loctite 592. Do not use teflon tape. Slivers will get in your needle and seat.
O Online: Content
I use Permatex Seal Lock. It's a combination thread sealer and blue thread locker
1950 Chevrolet 3100 (Ol' Roy)
I have the teflon tape that’s designed to work with gas, it’s kind of pink and thicker than the white.
Insomniac
Insomniac
I'm confused. On my carb, (Rochester B) the fuel line is flared and you just have to tighten the flare nut. The other side of the adapter threads into the carb body; I have copper washer there to stop leaks.
No tape or pipe dope required anywhere.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
O Online: Content
The threads on his carb might be worn out/stripped or something.
The thread going into my Carb is 1/8 NPT.
Brian Moore
Carburetion specialist
Probable causes:
(1) threads in carburetor housing are now worn TOO DEEP, due to overzealous previous owner overtightening of the fitting OR the use of one of the forms of Teflon.
(2) the carburetor casting is cracked at the fuel inlet, due to a previous owner using some form of sealant/lubricant (Teflon is a wonderful lubricant).
Possible solutions (if you are dealing with a 1949 truck as indicated in your signature block):
(1) Remove the aftermarket Rochester B and install an original Carter type W-1 carburetor.
(2) Remove the aftermarket Rochester B and install an aftermarket Carter YF.
(3) Replace the air horn on the Rochester B with a new old stock or good used one.
(4) Machine a new brass fitting with slightly oversize threads. This fix will work for (1) but not (2) of the causes. This fix normally reserved for use with EXPENSIVE carburetors.
Jon
The Carburetor Shop
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I second this, a copper "crush" washer seams to do the trick.
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
Some of the "B"'s have pipe thread (tapered) into the carburetor casting, others have a uniform diameter thread, and a gasket.
Jon
The Carburetor Shop
Insomniac
Insomniac
Here's another idea that might work for you...Fixing threads
Gord 🇨🇦
AD Addict & Tinkerer
Although JB Weld is resistant to gas, it is not resistant to alcohol.
If you use gas mixed with ethanol, the long term effects are debatable and not really known.
Phil
Project Journals
Stovebolt Gallery Forum
While JB weld is good for many things I am not going to do that on a carb.
Brian Moore
O Online: Content
JB Weld Tank Weld is ethanol tolerant and can be used to patch holes in fuel tanks.
I wouldn't use it for thread repair, though since the vibration might break it loose and cause an underhood fuel leak.
carbking Jon has your answer. Pitch your fire starter Rochester model B and find the correct W1 Carter that belongs on your '49.
If you HAVE to keep the Rochester and it has pipe threads you could try a helicoil style insert LINK.
Full disclosure, I have not tried an NPT insert, but have used helicoils on straight threads a number of times.
Crusty Old Sarge
Crusty Old Sarge
T Online: Content
I was thinking about a Helicoil too. Didn't know they were available in NPT, make sense though.
~ Craig
1958 Viking 4400
"The Book of Thor"
1960 Chevrolet C10
"A Family Heirloom"
If you go with a helicoil, use a liquid thread sealer, you now have twice the threads to seal, the original size and now the added helicoil size.
I`d try this first. Let it cure a couple days
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
What is the casting number on the air horn casting ?
Jon
The Carburetor Shop
Still waiting on the 592 to come in. I will let you all know what the results are once I do.
Brian Moore
O Online: Content
What's the 592?
Another "miracle in a tube" ! frown
Jon
The Carburetor Shop
Jon not sure I have seen a casting number on the air horn. Where should I look for one?
Brian Moore
Brian - I'm not Jon "carbking", but I can offer some current pictures from what I know to the best of my knowledge is a 1953-58 Chevy 235 truck Rochester B that you can take a look at and try to figure out what you have.
My info on this being a '53-'58 truck 235 carb comes from this Rochester B Identification thread put together by Jon "carbking" and "John Milliman" (the Big Kahuna) to help Bolters figure out what they have. The PDF files attached to this thread must be downloaded to read as they won't open for some squirrely reason.
Hope this may help. wink
~ Dan
1951 Chevy 3 window 3100
B air horn casting number
The Carburetor Shop
