| | | Forums66 Topics128,179 Posts1,057,157 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2021 Posts: 6,951 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,951 | I recently had an inline six rebuilt and was told to put a couple hundred miles of normal driving (including high speed driving) on the break in before changing the oil again. Engine now has 1000+ miles on it and runs perfectly with no smoke or burning.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Dec 2020 Posts: 1,972 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,972 |
~ BD. "You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
| | | | | Joined: Feb 2019 Posts: 4,510 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,510 | Congratulations. Now the fun begins!
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Nov 2021 Posts: 1,403 'Bolter | | 'Bolter Joined: Nov 2021 Posts: 1,403 | I would suggest following BC59's recommendation. I am struggling to get my rings seated (different engine but piston ring sealing is important to all engines). | | | | | Joined: Dec 2020 Posts: 1,972 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,972 | It`ll be fine. Just looking for all avenues.
| | | | | Joined: Dec 2020 Posts: 1,972 'Bolter | | 'Bolter Joined: Dec 2020 Posts: 1,972 | 35 minutes at 2000 rpm`s. Since then I've been taking short trips. 10 -20 miles at a time. 55 mph and 45 mph. Some speeds at 65mph. No stops for 5miles. Lucky I have some steep hills to climb in 1st and 2nd. Same to decelerate in 2nd. I`ll soon finish the 100-120 mile initial with the Penn Grade break- in oil. Drain and fill with SAE-30 and Lucas zinc. Additive. 500miles then and after SAE-30.
