4 members (Hush, Jay R, Lugnutz, 1955 1 Series), 77 guests, and 1 robot.
Topics128,213
Posts1,057,479
Members48,473
Moderated
Moderated
I have a 1952 GMC 250-22 Panel Truck. I am trying to find rear shock absorber to fit.
I did find specs that suggested using Heavy Duty with Nitrogen gas Extended length 18.5 to 19.0 inch - Collapsed 11.5 to 12.0 inch - 7.0 inch Stroke
any help with manufacture and part would be greatly appreciated.
Last edited by Gdads51; 08/30/2026 3:48 PM. Reason: edit title for more details/move post to best forum
sawdust54 #1610437 08/30/2026 12:35 PM
Look here, https://www.shockwarehouse.com/pages/monroe-measurements . You need the compression, extension, travel, and mounting type, you should find something close too fitting.
Here is the Gabriel measurements, https://gabriel.com/sites/default/files/2026_LMD_MD_Mounting_Codes_Guide.pdf
sawdust54 - First off, Welcome to Stovebolt! wave
That being said, I've added info to your title and moved the post to the best on-topic forum for further discussion. wink
More to come...
~ Dan
1951 Chevy 3 window 3100
Well, it took me a while to go down that rabbit hole dang , and unfortunately not alot to show as far as a modern replacement rear shock for your Panel. frown
Roaming through multiple paper GMC and Chevy Master Parts Books, plus electronic Parts Books resources as well, led me to at least some possibly useful facts. I found that the 1952 Chevy 3800 1 Tons (which should be the same as the corresponding GMC 250-22 1 Ton trucks) listed the rear brakes as an RPO (Regular Production Option) 200 under the complete RPO GM# 3707900.
The shocks for the Chevy RPO are listed as Model 967U / Valve Code 8J10/A1 and for 1950-53 the shocks were listed individually as GM# 5513639. As of 2-1-55, they were replaced by GM# 5303490, which are identified as Model 667U / Valve Code 8J10/A1 and again cover the years 1950-53. It gets even more confusing in later years as many changes continued through 1979, but the latest GM# 4940673 is listed for 1950-53 1 Tons and 1955-62 D-D 1 Ton (Dubl-Duti Panel Trucks) with a different Model code 684U.
After all that rabbit hole chasing, none of the numbers actually cross reference to a modern shock. :
As "Joe H" suggested above, you will likely have best results finding something to fit by comparing all your existing shock specs/details (including top and bottom mount styles/designs) with the Gabriel Guide he linked.
Best of luck in your search! thumbs_up
PS - Below are pictures of a 1953 GMC 250-22 Dealer pamphlet I recently acquired, just offered in case you and others would like to see it and perhaps use some of the info it contains as it very close to the same as your '52. NOTE: Rear shocks for the 250-22 are listed on the last page under "options".
~ Dan
Dan:
I have a .PDF of a similar pamphlet dated August of '52 (yours is dated March of '53) that says rear shocks are standard equipment. Yours says "in front".
If you's like a copy of mine send me your email address in a PM.
Originally Posted by Bill Hanlon
Dan:
Bill - PM sent. wink
Thanks! thumbs_up
~ Dan
