1 members (Shade Baby), 58 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#1610294 08/28/2026 11:43 AM
Leo
Offline
Moderator
Moderator
My truck is a 1953 3100 converted to 12 volts. My turn signals worked fine one day and not at all the next. The brake lights and parking lights are fine. I pulled out the flasher, 3 prong, and the outer cover came off, leaving the flasher behind. I replaced the flasher and I still have no signal lights. I am thinking about a bad ground somewhere, where do I begin?
Leo #1610308 08/28/2026 2:29 PM
I'm assuming you have a Signal Stat 900 (or one of it's clones). Are the front turn signal lamps integrated into the parking lamp sockets or are they separately mounted on the fenders?
Rear brake/turn lamps use the same filaments, so wiring from the turn signal switch to the rear lamps are okay.
My guess is that the fuse between the "X" (see picture) terminal on the flasher and 12 volts is blown.
Leo #1610323 08/28/2026 5:04 PM
Leo
Offline
Moderator
Moderator
The parking lamps have always served as signal lights when we rewired the truck 15 years ago. The fuse is good, double checked the fuse by putting in a spare one. Everything else works fine, all the bulbs are good.
Leo #1610340 08/28/2026 6:30 PM
U
U Offline
I have an old Signal-Stat 800 and sometimes I have to jiggle the handle to make my turn signals work. It might be time to upgrade to something new.
~ John in Utah
Here We Go
Follow in his DITY Bay
Leo #1610351 08/28/2026 11:39 PM
Insomniac
Insomniac
Are you still using the same switch as in this post?
Leo's switch
After 15 years, I wouldn't be surprised if it died. First thing to do is check that there is power to the switch.
If the switch is no longer working, ISTR that there was a thread on how to disassemble the switch and clean up the contacts. Maybe someone can find it?
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Gord&Fran #1610388 08/29/2026 10:52 AM
Leo
Offline
Moderator
Moderator
Leo's switch
No, that old switch was in my truck when I purchased it but was never used. We put a new one in.I will test out the switch.
