2 members (KEVINSKI, 55shaker),
125
Mod | | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | hello, it appears that my starter has bit the dust. Think water damage. does anyone sell rebuilt or new replacements? looked at the usual on line parts and didnt see anything. If it cools off later will pullit and see what inside looks like. Thanks for any help | | | | | Joined: Feb 2005 Posts: 1,684 'Bolter | | 'Bolter Joined: Feb 2005 Posts: 1,684 | I saw one here at The Filling Station: LINK
~ John in Utah 1946 1/2Ton w/4-speed manual transmission w/1960 235 engineHere We GoFollow in his DITY Bay- If you think about it, it has been one year ago today!
| | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | I have bought 2 from Napa. Take you old one with you to match up. I recommend keeping the old one until you know that the new one works as it should. You may be able to clean up the contacts and maker her work again. Never know what a little TLC will do to these old trucks/parts! Good luck!
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Feb 2004 Posts: 29,881 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,881 | Take the switch off the top of the case (2 screws) and clean up the copper contacts on both the starter housing and the switch itself. You can also touch a battery cable to the starter lug momentarily to see if the motor will spin, without unbolting the whole starter. Rock Auto sells replacement switches. The same switch works for both 6V and 12V starters. www.rockauto.com/en/moreinfo.php?pk=445442&cc=1326091&pt=4188&jsn=619Jerry
| | | | | Joined: Jul 2009 Posts: 367 'Bolter | | 'Bolter Joined: Jul 2009 Posts: 367 | well got the starter out this morning. The switch lookss ok but when i tipped the motor water came out. found a rebuilder in town that will be my next stop. tried napa for a rebuilt and no luck. will update in a few days Thanks | | | | | Joined: Sep 2009 Posts: 6,035 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,035 | There is a related thread on the same starter you have HERE including the original Delco Remy detailed parts lists for the starter components needed for rebuilding yours. Your local rebuilder likely already has the info, but if not, you can certainly show him the document pictures for help in tracking down parts if needed.
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Oct 2021 Posts: 6,963 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,963 | I bought a new one from NAPA about 2 years ago. I kept the original for potential future rebuilding but the new one seems like a decent unit. It was $79
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Sep 2009 Posts: 6,035 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,035 | Otto - You got a NAPA part number??? Would be helpful for folks if you could share.  Edit note - On second thought, isn't yours a 6V? He's looking for a 12v stomp starter, which has a different drive unit than yours.
| | | | | Joined: Oct 2021 Posts: 6,963 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,963 | Yes. It is a 6v stomp. Sorry about that. I forgot the 12v difference.
