Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 44 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1609860 08/21/2026 10:08 PM
The intake and exhaust valves on the 235 engine have a seal just below the spring retaining keys but no seal at the top of the valve shaft guide bushing to avoid oil seeping into the combustion chambers, why? Other engines do.
A good o-ring is all that is needed as long as the valve guides are not heavily worn.
The valve stems need some lubrication for a long life.
Personally, I am not a fan of modern positive valve stem seals on a 235. They seal too good for the amount of oil that is supplied to the rocker arm assembly in my opinion.
If you were to have the o-rings AND positive valve stem seals on a 235, you will not be happy with the results after a few thousand miles.
Positive seals are engineered to meter a small amount of oil down the valve guide to keep it lubricated. If you choose to use them, it's best NOT to also install the O ring seal under the split keepers. I only use positive seals on intake valves, and stay with the O rings and the sheet metal deflectors under the spring retainers on the exhaust valves. The intake guides are subjected to manifold vacuum on the underside, which justifies the positive seals, IMHO.
52Carl and Jerry, first let me say that I had never observed your personal depiction of yourselves that’s under your Stovebolt name. Both are very amusing. I got a chuckle out reading them.
As to you’lls position related to stem valve seals it makes a lot of sense to me.
Jerry you address “sheet metal deflectors “. What do they look like, do you have picture of it?
"Deflectors"- - - - - -the thin sheet metal rings about 1/2" tall that are sandwiched between the top of the valve spring and the spring retainer on some engines. They work with the O ring at the top of the valve stem under the split locks to keep oil from puddling on top of the valve guide. If a positive seal that clamps on top of the guide is used in addition to the O ring and the deflector, the guide will be starved for lubrication and it will wear out quickly.
Jerry, this 235 engine didn’t have those “deflectors.” Does it really matter if this engine should have them? If so where can I get some?
No, if it didn't have them originally (it varies according to the year of manufacture) there's no real need to add them.
Great! Then that gives me peace of mind.
Here's an Ebay ad for the valve spring oil shields used on small block V8s. I've also seen them used on stovebolt sixes on occasion. Whether or not they were original equipment, I'm not sure.
www.ebay.com/itm/137520184895?
