This is a 7 wire turn signal switch I bought from Jim Carter and decided to use the older one that came on my truck (looks more period). This switch will control brake lights as signals - needs a separate wire to each brake light bulb. Also has 4-way hazard flasher capability.
This is unused and in the original box with instructions. I disassembled it and painted it the same color as the steering column (original AD color per Jim Carter) and reassembled it.
The attached picture is from Jim Carter's website listing for the item, priced at $39.95, but is out of stock. It looks to be chromed, mine was black plastic (2nd picture shows the current color.)
Will ship by USPS. I'm guessing under $15 for shipping cost to US addresses.
