2 members (ArtA, papas52), 73 guests, and 3 robots.
Topics128,208
Posts1,057,452
Members48,471
24601
24601
Recently (as in 2 weeks ago) taken out of service from the Hytop, AL VFD. Everything works except the cab lights and the parking brake.
The deets:
1976 Dodge W350 4WD
360 CID engine
Pierce/Waterous 300 GPM pump
250 gal. tank
can pump and roll
1976 Dodge/Pierce minipumper/brush truck
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
Moderator
Moderator
2 Offline
Is it for sale?
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
24601
24601
As stated in the title, this thread is for Mike B.
smile
Enjoy your day, Don!
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
That's a neat truck, somebody is going to have fun with it, sadly it won't be me...I'm out of space!
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
24601
24601
Well, I finally got it to draft today. Had fun aerating the pond and refilling the tank.
It isn't a Stovebolt, but it is cool.
Engine 3 -- drafting!
2 inch suction line feeding an inch and a half straight nozzle.
150 psi in the pump, about 135 at the discharge. at 1800 rpm. Pretty good numbers for a 50-year old pump, I suspect.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Are you entertaining questions or is this for only Mike B.?
Jesus Christ said, "I am the way and the truth and the life. No one comes to the Father except through me." John 14:6
Authorized Pest
Authorized Pest
I think John will take questions about the truck. I believe he's enjoying it muchly. grin
It may take a bit before he responds. He's temporarily out of pocket.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
That's a really nice-looking rig. What is the dump valve - pointing in the 2 o'clock direction in your original post, and toward 8 in the pumping post? I'm familiar with such only as it applies to a tanker dumping into a portable tank. Thanks!
24601
24601
fyrboy -- *excellent* question!! And it was messing me up to begin with. The "Dump Valve" in this application allows you to dump pressure if you are taking water from a higher pressure source than you are comfortable with. Say, for example, I'm taking water from a city hydrant or from another truck with a 1,000 gpm truck -- this valve allows me to regulate the inlet pressure so I don't over pressure my little 300 gpm pump. It is a simple righty tighty, lefty loosey valve -- for drafting, I have it righty tighty as righty tighty as it can go.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
24601
24601
So if you are used to dealing with the full-sized jobs, and not these baby pumpers, you (like me) might get confused about that valve. When all else fails ... read the instructions. dang
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Thank you! Do you have an intake gauge to accurately assess incoming pressure? I'm familiar with sudden, intense intake pressures that have overidden plumbed intake valves & blown the bottom out of pumps.
24601
24601
No. All Pierce outfitted this with were the pump pressure and the pressures at each of the discharge valves.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Looks like the gauge for Discharge No 2 is missing a needle. A dual PSI/kPa gauge.
Apparently there are discharge ports in various places on the truck, as Discharge No 2 isn't visible in the photo.
Cool stuff.
24601
24601
Kevin -- Discharge#2 pressure gauge's needle isn't missing -- its laying in the bottom of the dial. Discharge #2 is on the passenger side.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Does the suction hose have a strainer, or are you chumming minnows to feed the bigger fish?
Well, OK! Seems like it might have trouble indicating the pressure from the bottom of the dial. grin
24601
24601
Kevin -- I've been told by competent authority that a "good" engineer doesn't need a gage, he's in such tune with his equipment that it will sing to him songs of pressures, rpm's, flow rates, narwhal mating rituals and Appalachian moonshine recipes. Of course, that was right after he had cooked up some corn squeezins' ...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
I can believe that. My ears tell me things when driving my 7.3L diesel. When things don't sound right, a guy starts checking. When things sound right, the smile comes on.
24601
24601
Yeah, well the flip side of that is when the engine gurus listen to the engine, cock their heads and say "Did you hear THAT??" and then proceed to tell you that the engine that was "recently rebuilt" needs to be torn down again because its in imminent danger of grenading due to a rod knocking. My VA disability is a loss of hearing so I can't hear whatever it is they're hearing. I learned from Jerry that when the engine experts tell you that a funny noise is telling them the engine is about to fail catastrophically I believe them. It was not a fun day in Old Truck Land.
frown
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
Fortunately, I haven't forgotten most of the MOPAR tricks I learned while playing in the 4WD truck pulling sandbox, and I've got a few engine parts left over from those days. John's firebolt just might get some sneaky upgrades before too long! The warmed-over "440" engine we ran back then made a few dyno runs in the 700+ HP range at 6500 RPM.
24601
24601
Jerry ... Here are the pics I promised in the PM. At this point, I don't care if the red neck 360 grenades or not. Notice the absence of the flywheel cover...
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
HMMMMM- - - - -that oil pan to crossmember clearance seems to be a bit snug- - - - -but that can be dealt with by unbolting the front motor mounts and jacking the engine up a little. I think I've got a fixture stashed away somewhere for just that purpose. I'd really like to see what those rod journals look like- - - - -before they can be inspected through holes in the block!
I just did a little number crunching- - - - - -one of my 383 MOPAR engine blocks bored .060" oversize, with a 1/4" extra stroke 440 crankshaft and 454 Chevy pistons and rods works out to 467 cubic inches. That ought to get you on scene before the fire starts!
Moderated by  69Cuda
