2 members (Greg_H, 1 invisible),
106
Mod | | | Forums66 Topics128,263 Posts1,058,136 Members48,482 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2026 Posts: 80 'Bolter | | 'Bolter Joined: Mar 2026 Posts: 80 | Starting a rebuilt 54 GMC 302, starter has been rebuilt, battery cables have been replaced (Upsized) It still cranks over really slow! The former owner said his dad ( it was dads truck) used to run an 8 volt battery, hadn’t heard this trick before, anybody had experience with this? | | | | | Joined: Dec 2002 Posts: 3,446 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,446 | The experts will say to reclean all of the grounds. Use good wire straps ( (not the woven type).
| | | | | Joined: Oct 2021 Posts: 7,012 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 7,012 | Solve the problem. Don't try to cover it up with the wrong battery. You'll eventually damage your gauges and burn out your generator.
My truck is 6v and spins over as fast as any modern vehicle with a 12v system.
Make sure all your battery cables are 00 gauge. Make sure all your connections are perfectly clean and tight with no frayed wire or crappy connections.
Make sure your generator and voltage regulator are in perfect working order (7.2v-7.5v while charging).
Make sure that the battery is at full charge at rest (6.2-6.4v). If your battery only registers 6.0v at rest, it's discharged and probably has a bad cell.
Make sure all ground connections are perfect, clean, and tight.
Make sure your starter is in top order as well.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Feb 2004 Posts: 29,923 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,923 | An 8 volt battery is a solution to a nonexistent problem. Get the cable connections clean and tight, and use at least #0 AWG welder cable for hot and ground leads instead of conventional battery cable. In order for an 8V battery to work, the voltage regulator must be set to 9.5 volts or more. Headlights, points, charging system components, and other electrical parts fail quickly from the over voltage. Jerry
| | | | | Joined: Feb 2020 Posts: 80 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 80 | Pull the spark plugs and see how it cranks over.
51 GMC 100 with 59 chevy 261 under the hood. 3 on the floor with 3.42 gear.
