1 members (Shade Baby), 58 guests, and 5 robots.
Topics128,271
Posts1,058,314
Members48,485
#1609023 08/06/2026 3:16 AM
Starting a rebuilt 54 GMC 302, starter has been rebuilt, battery cables have been replaced
(Upsized)
It still cranks over really slow!
The former owner said his dad ( it was dads truck) used to run an 8 volt battery, hadn’t heard this trick before, anybody had experience with this?
The experts will say to reclean all of the grounds. Use good wire straps ( (not the woven type).
Another quality post.
Real Trucks Rattle
Solve the problem. Don't try to cover it up with the wrong battery. You'll eventually damage your gauges and burn out your generator.
My truck is 6v and spins over as fast as any modern vehicle with a 12v system.
Make sure all your battery cables are 00 gauge. Make sure all your connections are perfectly clean and tight with no frayed wire or crappy connections.
Make sure your generator and voltage regulator are in perfect working order (7.2v-7.5v while charging).
Make sure that the battery is at full charge at rest (6.2-6.4v). If your battery only registers 6.0v at rest, it's discharged and probably has a bad cell.
Make sure all ground connections are perfect, clean, and tight.
Make sure your starter is in top order as well.
1950 Chevrolet 3100 (Ol' Roy)
An 8 volt battery is a solution to a nonexistent problem. Get the cable connections clean and tight, and use at least #0 AWG welder cable for hot and ground leads instead of conventional battery cable. In order for an 8V battery to work, the voltage regulator must be set to 9.5 volts or more. Headlights, points, charging system components, and other electrical parts fail quickly from the over voltage.
Dave1234 #1609032 08/06/2026 12:39 PM
Pull the spark plugs and see how it cranks over.
51 GMC 100 with 59 chevy 261 under the hood.
3 on the floor with 3.42 gear.
