5 members (Hotrod Lincoln, carbking, Ponchogl, delky, Otto Skorzeny), 150 guests, and 2 robots.
Topics128,196
Posts1,057,385
Members48,471
#1608713 07/30/2026 4:57 PM
Has anyone ever used this under the fenders or inside the doors? 3M 03584 Black, Professional Grade Rubberized Automotive Undercoating, 16 oz.
Thanks Shade Baby
1950 Model 3104 5-Window
"Back In Time"
Follow in the DITY
That's probably equivalent of what I used for undercoating. I used a product by UPOL in aerosol cans. Seems to do OK, but what you're putting it on has to be clean. I used some black adhesive foam sheets inside the doors and on the underside of the roof to help deaden the noise. For noise reduction, the more mass that's there is better. Even a blob of tar will help the doors go clunk instead of clang, but that's smelly.
Insomniac
Insomniac
I believe that's what I used. However, I used a shutz gun instead of an aerosol can.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Walmart had them on sale for $9.99 a can. The underside of the fenders has been primed with epoxy, I will follow all directions before spraying The 3M under the fenders. Gonna use Dynamat for everything cab related, but thats going to be a bit. need to weld up a lot of holes. Purchased a bunch of coupons to practice with before I attempt repairing cab!
Shade Baby
"Back In Time"
Follow in the DITY
