8 members (Stovebolt48, 1955 1 Series, Bill Hanlon, fonz8261, latroca52, klhansen, JoergK., 1 invisible),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,195 Posts1,057,373 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 270 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 270 | Has anyone ever used this under the fenders or inside the doors? 3M 03584 Black, Professional Grade Rubberized Automotive Undercoating, 16 oz.
Thanks Shade Baby | | | | | Joined: May 2015 Posts: 11,183 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,183 | That's probably equivalent of what I used for undercoating. I used a product by UPOL in aerosol cans. Seems to do OK, but what you're putting it on has to be clean. I used some black adhesive foam sheets inside the doors and on the underside of the roof to help deaden the noise. For noise reduction, the more mass that's there is better. Even a blob of tar will help the doors go clunk instead of clang, but that's smelly.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Jul 2000 Posts: 2,207 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,207 | I believe that's what I used. However, I used a shutz gun instead of an aerosol can.
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Jun 2023 Posts: 270 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 270 | Walmart had them on sale for $9.99 a can. The underside of the fenders has been primed with epoxy, I will follow all directions before spraying The 3M under the fenders. Gonna use Dynamat for everything cab related, but thats going to be a bit. need to weld up a lot of holes. Purchased a bunch of coupons to practice with before I attempt repairing cab!
