2 members (tclederman, greenie-reddy), 150 guests, and 0 robots.
Topics128,109
Posts1,056,266
Members48,439
#1608356 07/25/2026 1:37 AM
54 gmc ,anyone change this seal with the steering box still on the truck .It looks like it is accessible with the drivers wheel off .I took the seal out of a extra steering box I had and it came out easily .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
I think it could be done. I did it when I had the steering gear off the truck for a full cleanup and rebuild, though. The pitman arm would have to come off of course, and you'd probably need a socket of the right size to seat the new seal. I assume you're going with the more modern lip seal.
Yes newer seal waiting for it to come in
"The Journey"
Follow in the DITY
I changed mine (52 GMC, same seal) with the box mounted in the truck. You are supposed to pull the pitman shaft, but some of us have used a Lisle seal puller to drag out the old seal with the shaft in place.
Picture below is a leather stock seal being pulled with the Pitman shaft removed.
GM part number for the lip seal is 7801626. Federal Mogul 313842
It'll make your truck faster because the same seal is used on 1962-83 Corvettes.
That original seal is a piece of felt. It should be ashamed to call itself a seal.
Another optional seal is SKF 11055. That's the one I used. I have no seepage around the shaft, but a touch at the worm shaft adjuster threads.
[on edit] Seems that RockAuto is out of stock on that seal. I guess we've bought them all. wink
I think the original was leather.
Napa should have the seal, SKF 11055, order two of them, they bend and deform pretty easy. It's not hard to pull the sector shaft back, at most, you might have to make a new gasket. If you don't mess with the adjustment, it will go right back in. Installing the seal with the shaft in place will be much harder than without the shaft, start making a seal driver now. A small diameter pipe with the right ID to slip over the shaft and long enough to hit it squarely with a small hammer. Even with a good driver, it's easy to bend the seal.
I went one step further to make my 53 3100 go even faster by putting EPAS power steering on that is the same as the old Corvettes.
One more question after I get the seal in is gear oil going to stay in the box or should I use corn head grease.The way it is now is it has grease in the box and the box leaks oil out were the seal is
"The Journey"
Follow in the DITY
I would not use gear oil in your steering box. GM has called for NGLI 0 or 00 for steering boxes. Real soupy grease. Corn Head Grease is a suitable substitute.
Ok thank you Kevin ,I will see if I can find the proper grease if not I have the corn head grease .
"The Journey"
Follow in the DITY
A quick and easy substitute is gear oil and chassis grease in a 50/50 mix, just make sure what ever you use is soupy. The worm gear and roller balls need to oily wet at all times and if the lube is too thick it can't flow into the ball nut. Penrite and Dynolite both make proper steering box lube if thats what you want, but the corn head grease will work just as well.
Here is what I'm using in my stock box with EPAS Performance electric P/S and Howe 1:1.5 steering quickener. I will also be running an 8" front tire.
I used this stuff in my C60 steering box, which seemed to hold exactly one of these quart containers full.. https://www.tractorsupply.com/tsc/product/super-s-cotton-picker-spindle-grease-00
And it only costs $7.49!
