3 members (tclederman, TUTS 59, 1 invisible),
132
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,279 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | I'm looking at possibly buying a 1950 Canadian built GMC but I have a few questions. I know the Oshawa built units used the Chevy 216 instead of the GMC 228, so am I to assume they used the lighter/shorter, Chevy frame too, making these just chevy trucks in GMC trim? Brian | | | | | Joined: Sep 2010 Posts: 2,315 'Bolter | | 'Bolter Joined: Sep 2010 Posts: 2,315 | My 54 gmc 9300 came with the Chevy engine 235.I had a 51 parts truck and it had the 216 .The frame as far as I now is no different than a Chevy frame with possibly differences for the different front grill . | | | | | Joined: Sep 2009 Posts: 5,899 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,899 | Ribside - I recently acquired an original 1947 Canadian Chevy/GMC Truck Shop manual and a 1948-50 Canadian Chevy/GMC Truck Shop Manual Supplement, which I haven't actually had a chance to delve into yet. When I get a chance I'll try and do a bit of reading in them to see what can be found on your question.  Can you provide the Model# from the truck you're looking at? It will help me search through the books. In the meantime, perhaps some of our other Canadian built GMC Owners will chime in with what they know?
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Gdads51, Yeah, it's a 9314 9= GMC 3= 1/2 ton 1= 116" WB 4= Pickup Engine= C370137 (Unknown) I suspect C= 216cui and serial #? Paint Code= 30 (Unknown) I can't find GMC paint codes Trim Code= 394 (Unknown) I can't find GMC trim codes
I don't know why GM would market GMC's along with Chevys, being they are the same truck, coming off the same line with only the hood, grill, dash trim, and oddly, the GMC radiator being the difference. In the US, one bought a GMC because it had the bigger, better motor and stouter frame. I can only assume GM did this so they didn't have to build a dedicated GMC plant in Canada.
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ribside, I don't know why GM Canada built Canadian GMC light trucks the way they did, possibly no casting capacity for making the better engineered GMC engine. The GMC engine is a bit longer than the Chevy engine, that requires a different frame front crossmember. As far as the American GMC frames being "heavier" I have no way to prove or disprove that statement. | | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | 3B, I was informed the GMC frames used slightly heavier gauge steel. | | | | | Joined: Sep 2009 Posts: 5,899 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,899 | The Canadian 1948-50 Maintenance Manual Supplement shows both the Canadian Chevrolet and GMC offerings used the same Chevy 216 engine, so it can be presumed that both trucks used the same frame and drivetrain. Your assumptions about why GM of Canada did what they did could be valid, but we'll probably never know for sure.
Your "C370137" engine serial number matches known Canadian serial number formats. Somewhere I read that the "C" designation was given to the "Light Commercial Truck" 216 models, but I've lost the link to where that came from unfortunately.
I too have unfortunately not been able to find information on decoding either the trim or paint codes, yet.
| | | | | Joined: Jul 2000 Posts: 2,193 Insomniac | | Insomniac Joined: Jul 2000 Posts: 2,193 | You might find this site useful. Canadian Cars and TrucksENGINE PREFIXES to 1953: 216 CAR: NO PREFIX 216 LIGHT COMMERCIAL: “C” 216 TRUCK: “X” 235 TRUCK: “T”
Gord 🇨🇦 ---- 1954 1/2 ton 235 4 speed | | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Gord, Thanks, I have seen that site and it is chock full of info, unfortunately nothing I found regarding the codes. I'm assuming Trim 394= Deluxe Cab, as the truck in question has corner cab windows. Paint Code 30 may be a dark blue, as that's what shows in the motor bay. I'm waffling on buying this truck because I want a 'real' GMC with a SM420, not a poser with a 3spd. But it is a nice truck. Brian | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Ribside, corner windows are not an indication of a deluxe cab, deluxe cabs can be found with three windows and five windows, the corner windows were a separate option. | | | | | Joined: Dec 2013 Posts: 41 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 41 | Ah, OK. This truck does not have the signature Deluxe window trim or other doodads, so that make sense. | | |
