4 members (Wally / Montana, Bill Hanlon, TexasJim50, jkreiner), 49 guests, and 0 robots.
Topics128,074
Posts1,055,914
Members48,429
#1607301 07/07/2026 12:10 AM
I posted previously that the engine in my 66 C10 was partially disassembled when I got the truck. The Rochester B was on the manifold but the accelerator linkage was disconnected. I found a spring loose in a box of spare parts… anyway, I can see something is not right with the throttle lever. There is nothing for the idle adjustment screw to push against to adjust the idle. I don’t really know how I got it to start and idle before. It won’t now. See pictures. And thanks for your help.
Professional Novice
I think I see the problem. It just hit me. Maybe some of you can see my mistake too. Thanks for all responses!
Professional Novice
Insomniac
Insomniac
Lever upside down. You are not the only one to make that mistake.
Choke lever
Gord 🇨🇦
1954 1/2 ton 235 4 speed
Choke lever
Thanks! That’s what I discovered after studying some pictures and drawings on the internet. I got out there this morning and corrected it. 😎. Thanks for the link!
Professional Novice
