6 members (Shade Baby, TexasA&M48Truck, tclederman, Hotrod Lincoln, Bill Hanlon, 1 invisible), 82 guests, and 2 robots.
Topics128,094
Posts1,056,483
Members48,444
T Online: Content
I’ve seen videos where they state that drilling a hole in the electrode provides a better directed spark and it achieves a more effective combustion. Opinion please.
Sounds like snake oil to me.
If it made any sort of measurable improvement, spark plug makers and performance parts makers would already be selling them.
1950 Chevrolet 3100 (Ol' Roy)
Verifiable combustion improvement is achieved by upgrading to a (GM style) HEI, where plug gap almost doubles going out to .060.
Short of that I'm skeptical (and that’s being kind).
Chuck
Hank: 46 Chev 1/2ton shortbed
2023 Miata RF Club
T Online: Content
Thanks for the response. I thought “too that’s snake oil.” I’ll stick with the known old techniques .
Ive read a lo about HEI configuration and though I’ve been tempted I’ve backed away because of all the changes that go along with it.
H Online: Content
Sounds sort of like the "Fire Injector" plugs that J.C. Whitney used to sell about 50 years ago- - - - -the ones with six (Count 'Em!") ground electrodes. I believe the marketing director for the company that made those things was P.T. Barnum!
T Online: Content
Recollecting my years in aviation, I must say that old piston engines all the way to radial engines used multi electrode, some 2 others 3 electrode. Probably due to high compression.
H Online: Content
I seem to remember a special gap-setting fixture for those aircraft plugs- - - -one that used a cone-shaped device to move all the ground tabs in or out equally. The 28 cylinder radial engines on the big planes had 56 spark plugs- - - - -two per cylinder, and two complete magneto systems. 224 plugs on a 4 engine plane!
AD Addict & Tinkerer
This thread is starting to get way off of stovebolt engines. Time to rope it in guys!
Phil
Project Journals
Stovebolt Gallery Forum
The spark or arc, will jump to the closest ground it can find, doesn't matter how many grounds you have around the electrode, it will go to the closest. If you drill a hole in the ground, the arc will jump around the opening on the sharp edges, it will never go through the hole. All the hole will do is introduce a slightly extra bit of mixture at the arc.
Indexing the plugs so the open side of the ground is facing the chamber will do more good then a hole will, but you will never see the gains of your hard work indexing them on a truck.
I've run lots of plugs and distributors on my machine, I've never seen the arc change with different plugs.
Insomniac
Insomniac
Drill a hole in the electrode? Too much work for me!
NGK makes "V power" plugs where the electrode has a groove. They make many claims about how they increase performance. I'm skeptical...
However, if one of you 'bolters make YouTube videos, NGK might send you a set so you can make a review.
Gord 🇨🇦
1954 1/2 ton 235 4 speed
