0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2023 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 235 | I will be needing a new Radiator from US Radiator my questing for the 235 is a 3 or 4 core sufficient
Shade Baby | | | | | Joined: Feb 2000 Posts: 5,191 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,191 | 3 row will flow more air than a four row. A four row will hold more coolant because it's thicker, but less air flow because it's thicker. Aluminum radiators use two rows of a much larger tube, thus more coolant and better air flow. It really comes down to cost and the coolant load you are going to put in it. A stock 235 will work with a 2 or 3 row, or you can step up to a four row as long as you have a decent fan. Just remember, the aftermarket radiator will be a pressure unit, where the stock was open to atmosphere. The heater core will determine how much pressure you can run, most were designed for zero pressure.
If you are going to add A/C, I would lean towards more air flow, most any new radiator will cool the motor, but you need air flow to cool the A/C condenser, and a thick radiator may not work for you with the slow idle and factory fans of a 235.
| | | | | Joined: Jun 2023 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2023 Posts: 235 | Thanks, i did not even think about the Harrison Heater core. 3 row on the rad will be just fine | | | | | Joined: Mar 2007 Posts: 3,371 Crusty Old Sarge | | Crusty Old Sarge Joined: Mar 2007 Posts: 3,371 | While a better flowing radiator will help, a better coolant make a huge difference. When I was deployed in the Middle East we would use a coolant that was formulated for desert environments. It literally dropped the operating temp of Power Station Generators by 20 degrees. That massive difference at a 128 degree air temps. The biggest drawback to using this type of coolant is you cannot add water to it. While it may not be something that everyone would use it works, it's at least worth reading about http://www.evanscooling.com/coolants/
~ Craig 1958 Viking 4400"The Book of Thor"Read the story in the DITY1960 Chevrolet C10"A Family Heirloom"Follow the story in the DITY Gallery'59 Apache 31, 327 V8 (0.030 over), Muncie M20 4 Speed, GM 10 Bolt Rear... long term project (30 years and counting) If you don't like driving yourTruck, you won't drive yourTruck..| Living life in the SLOW lane | | | | | Joined: May 2015 Posts: 10,997 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 10,997 | If you never see freezing temps, the best coolant is --------- WATER. Yep, just plain ol' water. But a Corrosion inhibitor package should be added.
Evans coolant is 100% Propylene Glycol, which doesn't have as good a heat capacity as the standard 50/50 ethylene glycol coolant, and plain water beat both of them in it's heat capacity properties. One downside of water is that it evaporates or boils away, which is why pressurized cooling systems were developed. Evans doesn't have that issue, but in the same cooling system, will not beat water in heat transfer properties. It won't boil, but the engine will run hotter if the radiator isn't up to the task.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | |
