4 members (Bill Hanlon, ShopRag, HandyAndy, 1 invisible), 67 guests, and 2 robots.
Topics128,049
Posts1,055,676
#1606309 06/23/2026 12:59 PM
During teardown of the 235 I found one lifter with small chipped edge on the cam lobe side.
Should I replace all of the 12 solid lifters or just that one (if I can find one.)
Was there any noticeable wear on the cam lobe itself? Pictures of what you found/find would help us help you best. wink
Others will likely chime in on the do's and don'ts of replacing lifters on a used cam.
~ Dan
1951 Chevy 3 window 3100
Crusty Old Sarge
Crusty Old Sarge
I recently had my lifters resurface by Rocker Arms Unlimited. They did an outstanding job and the cost wasn't terrible, $65.00 to do the Set.
https://www.rockerarms.com/
235 Lifters
~ Craig
1958 Viking 4400
"The Book of Thor"
Read the story in the DITY
1960 Chevrolet C10
"A Family Heirloom"
I'm in the process of building a lifter refacing jig for my lathe. I'll be able to put either a 60" or a 72" radius on the bottom of the lifter. I'll be using a die grinder and a 400 grit ROLOC sanding disc, followed by polishing with a ScotchBrite disc.
Gdads51, I’ll be away from my beloved engine till mid July so I’ll post pics then.
Jerry, P.T. Barnum!!! JC Whitney catalog! Wow ! I stayed at the P.T. Barnum hotel in Connecticut decades ago.
