3 members (wilbur53, 2 invisible),
71
Mod | | | Forums66 Topics128,109 Posts1,056,572 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | I needed to replace the manifolds on my 250 and bought a manifold set from a 292 industrial engine. I had it home and installed on my engine before I realized that it had no provision for a PCV valve and no heat riser in the exhaust. It also had a larger exhaust outlet, but I can deal with that. And I’m not too concerned about the heat riser. It does concern me that it has no port to connect the PCV line to. Suggestions? Thank you.
Professional Novice
| | | | | Joined: May 2015 Posts: 11,105 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,105 | Easy enough to drill and tap a hole in the intake manifold for the PCV connection. Cast iron is pretty easy to drill and tap.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | If you don't want to try to drill and tap the intake for a PCV fitting, make a 3/4" thick aluminum spacer between the carb and the manifold, and drill and tap it for a 3/8" NPT brass vacuum nipple. Jerry
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Does it have heat under the intake since there is no heat riser valve? Without a heated intake, it will run really bad till it gets enough heat in the intake to vaporize fuel. I went down that road running three carbs on a home made intake, it took a long time for a mild steel intake to heat up and run right.
The carb spacer is a good idea, it will spread the oil vapors to all six cylinders instead of just the center ones. Drilling the intake and threading would be easy also, it only takes a few threads and some loc-tite to hold the fitting. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 |
Professional Novice
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Joe, I took the manifolds off of the engine and separated them. I wanted to know if there was heat going to the intake, and there is. There is a threaded port on the intake that was plugged. I removed the plug and found a hose adapter that I can screw in there to run the PCV hose to. SO, I think it will work out. Thanks again for all comments.
Professional Novice
| | | | | Joined: Feb 2000 Posts: 5,228 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,228 | Sounds like you are good to go with the benefit of larger exhaust pipe. Run the bigger pipe to the muffler, then scale down to 2 for the tail pipe. Thats how most of the HP cars were made, by the time the exhaust gases exit the muffler, they are cooled down and don't need the bigger pipe. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Thanks! I got the PCV line ran to the adapter on the intake. Carburetor cleaned and mounted. Linkage connected. No exhaust pipe yet. But did (finally) get it running on an auxiliary fuel tank. 😎. Lots more to do, of course, but still I’m pleased with the progress. Here’s a short video of this engine running for the first time in 26 years (according to the previous owner). Short video of first time my 250 is running in 26 years
Last edited by Gdads51; 06/11/2026 1:26 PM. Reason: convert basic web link to hot link
Professional Novice
| | | | | Joined: Oct 2021 Posts: 6,888 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,888 | Cool. Sounds like an airplane.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Aug 2010 Posts: 605 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 605 | Sounds really good. It's amazing how these old engines can be brought back to life.
| | | | | Joined: Feb 2004 Posts: 29,836 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,836 | One precaution- - - - -that open pipe into the valve cover will allow dust to be drawn into the engine by the PCV system. Either plumb that pipe to the "clean" side of the carburetor air filter, or add a filtered breather like this one: www.ebay.com/itm/194233850603?Jerry
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | Sounds really good. It's amazing how these old engines can be brought back to life. It’s true. Those old Chevy 6s are hard to kill.
Professional Novice
| | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 | One precaution- - - - -that open pipe into the valve cover will allow dust to be drawn into the engine by the PCV system. Either plumb that pipe to the "clean" side of the carburetor air filter, or add a filtered breather like this one: www.ebay.com/itm/194233850603?Jerry Thanks Jerry. With the air filter installed that hose is routed to a breather filter.
Professional Novice
