0 members (), 128 guests, and 2 robots.
Topics128,167
Posts1,057,021
Members48,458
This is my first classic so I don't know what I'm looking at. Does this clutch look like it needs replaced? Can you tell from the photos?
Is it slipping, squealing, or doing anything else weird?
1950 Chevrolet 3100 (Ol' Roy)
From the picture no
Just my $.02 worth, I'll agree with Dennys28, but add that the disc does have some wear displayed by the thickness of disc facings. The rearward facing of the disc looks more worn than the front IMO.
The original specs on the clutch facings (2) are listed as between .137 - .143 inches thick (each) when new per the 1952 Chevy Truck Data PDF (screenshot of the clutch info below).
~ Dan
1951 Chevy 3 window 3100
It was making a whisking noise from around that area in neutral so today I decided to look at it while my wife applied the clutch pedal. I spun the disc around a little and started it up, but it sounds like the noise went away. It does grind gears going into certain gears, but I think that's because I don't know how to shift this older transmission.
Just FYI, 2nd gear is synchronized between 1st and 3rd.
When shifting into 1st gear at a traffic light from neutral, put it into 2nd gear and then into 1st gear, and then release the clutch to avoid grinding 1st gear as happens when shifting straight from neutral.
