3 members (Otto Skorzeny, jay d, SmalltownTRKGuy), 112 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1604317 05/23/2026 1:49 PM
What oil are you guys using for your generators? I have 3-in-1 oil and firearm oils here if one of those would work. Otherwise, need to pick something up.
RBs36 #1604320 05/23/2026 2:10 PM
O Online: Content
FSM (1948-1952), page 0-4, says to use a few drops of light oil or engine oil.
I use 3 in 1 because the can already has the small pointy tip to easily access the cups on each end of the generator.
1950 Chevrolet 3100 (Ol' Roy)
RBs36 #1604321 05/23/2026 2:12 PM
Ive used 3-in-1 oil on generator and electric motor bearings with good experience. The 1936 "Instructions For The Care of Your Chevrolet Truck" says under "Generator Lubrication" - "Every 1,000 miles, lubricate the generator by putting a few drops of light oil or engine oil in the 2 oil cups."
~ Dan
1951 Chevy 3 window 3100
RBs36 #1604341 05/23/2026 7:20 PM
Thanks Gentlemen.
Ron
RBs36 #1604488 05/25/2026 6:05 PM
Originally Posted by RBs36
Thanks Gentlemen.
Ron
Ron: I use the 3 in 1 light oil too, I have a 1938 half ton pickup. Is there a wick in the tube where you're placing the oil drops? Many years ago I installed a generator rebuilt by a major company and at the time I did not know there waa supposed to be a wick in there, and the first time I added a few drops (maybe more) of oil the generator stopped charging because the oil got on to the brushes and so on.
After having it fixed by a local shop I found out about the wick, also the starter and distributor have wicks, and the water pump has a little cap or just the hole, for light oil for the packing inside there.
Later,
Glen
RBs36 #1604515 05/25/2026 11:31 PM
H Online: Content
If the generator has ever been rebuilt, there's a good possibility that the original open bearings have been replaced with sealed ones. That makes those lube cups nothing but cosmetic decorations. Some low output generators used a bronze bushing at the rear, which needs an occasional shot of oil in the cup.
RBs36 #1604521 05/26/2026 12:20 AM
Jerry, I had it rebuilt at a local shop, and it never occurred to me to even ask. They put new lube cups on it so I just assumed it needs oiled. I'll have to stop by and ask. Thanks for the tip.
Ron
RBs36 #1604522 05/26/2026 12:24 AM
O Online: Content
Or just put 3 drops in each one every once in a while and don't worry about it.
grin
Agree! Sometimes it's better not to know . . . ohwell
