0 members (), 311 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Took truck to town for breakfast. We were inside eating and there was a guy out side taking pictures of my truck
When we left this part was laying on my passenger side running board. I think the guy picked it up and layed it there. It may have been in parking lot before I arrived. Looked my truck over and see nothing missing. There are no marks like there was a bolt through it
with nut tightening down. Any ideas? Thanks Bill
37 half ton
1937 GC
Looks a little like the plates that go under the bed cross-sills where the bolts holding it to the frame go. But it likely didn't come off your truck. Could be about anything. ohwell
It does resemble a bed cross sill assembly part like those on my ‘46.
See the attached photo.
I think Sparky may have it pegged. Bill, check your bed to frame cross mounts on top of the wood blocks. It could be during assembly that the plate shifted and didn't get captured by the bed mounting bolt and vibrated the rest of the way out.
~ Dan
1951 Chevy 3 window 3100
Mine aren't going to do that. I tack welded those suckers in there.
Could be has a truck and had spare parts, being a nice guy he gave it to you.
U
U Offline
Mine are similar on my '46.
~ John in Utah
Here We Go
Follow in his DITY Bay
I think all you expert's are correct.will go under truck tomorrow and hopefully see something . Thanks for all of your input
1937 GC
Update: this forum is awesome! .update on my part ID. You expert's were right. After climbing under try this morning the bracket on the passenger side forward is missing. I have no idea how it could come out as bracket is bent over stile and cannot come out to the outside as bed support is tight against frame
Well Ithe good part is that I know what it is and where it's missing
Looks time might be a big deal.putting it back in. Thanks so for your wisdom. Bill
1937 GC
U
U Offline
Mine has a bolt going through it, so I don't see how it could fall off?
~ John in Utah
Here We Go
That part was left somewhere on the frame or something with the intention of installing it. It was forgotten and never installed. Luckily it fell off its perch in a place where somebody found it.
1950 Chevrolet 3100 (Ol' Roy)
I built the truck from ground up so I guess I have no one to blame but myself. 😕
1937 GC
Bill - We all know “stuff happens”. wink
I think it just great that someone was considerate enough to pick it up and put it where you could find it. That and folks here sharing knowledge to help each other out.
Doesn’t get much better than this IMHO! thumbs_up
~ Dan
Moderated by  klhansen, Rusty Rod
