2 members (Gdads51, ndkid275),
189
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,539 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2019 Posts: 4,472 AD Addict & Tinkerer | | AD Addict & Tinkerer Joined: Feb 2019 Posts: 4,472 | I just purchased a NOS headlight switch for my ‘52 and the dimmer acts like it’s dirty. The resistance coil is not broken and looks fairly clean. I doused it down with DeoxIT (contact cleaner) with little success. I also ran a piece of 400 grit paper on the wiper then used a small wire brush on the sections I could reach with a Dremel. It improved but still is intermittent. What's the best way to clean the resistance coil?
Phil Moderator, The Engine Shop, Interiors and Project Journals1952 Chevrolet 3100, Three on the Tree, 4:11 torque tube Updated to: ‘59 235 w/hydraulic lifters, 12v w/alternator, HEI, PCV and Power front Disc BrakesProject JournalsStovebolt Gallery Forum | | | | | Joined: Oct 2021 Posts: 6,722 'Bolter | | 'Bolter Joined: Oct 2021 Posts: 6,722 | I tried everything on Ol' Roy and The Bismarck.
After no success with either one dimming or brightening the dash consistently, I wired the dash lights directly to the taillight terminal so the dashboard is always lit at full power whenever the taillights and headlights are on.
Of course I can't remember a single time in my life that I ever thought the dash lights were too bright and needed to be turned down. All my vehicles' dash lights are always turned up to full brightness.
1950 Chevrolet 3100 (Ol' Roy)
| | | | | Joined: Mar 2010 Posts: 10,272 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,272 | I like Otto's plan of hot wiring for full brightness. I have the same mentality for stuck seat adjusters, as long as I can get the seat to be stuck all the way back.
| | | | | Joined: Mar 2014 Posts: 4,479 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,479 | Please make sure you have decent pressure on the coil from the wiper. If the wiper just loosely contacts the coil this can happen.
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
