2 members (Hush, delky), 141 guests, and 0 robots.
Topics128,126
Posts1,056,354
Members48,441
#1604773 05/29/2026 3:52 PM
Looking for recommendations on how to dislodge the cylinder head on my 235 that somebody in the past may have used hardening gasket sealer and I don’t have a hoist to yank it off.
For your information all related bolts are off.
Forget it I got the cylinder head loose. Used a wood chisel well sharpened and tapped it into the head to block mating surface, no damage to mating surfaces .
Thanks anyway
Texas - Sometime it just takes posting about a problem to figure out how to resolve it.
Glad you got it figured out! smile
~ Dan
1951 Chevy 3 window 3100
The easy way is to loosen the head bolts a couple of turns, pour about half a cup of oil into each cylinder, put the spark plugs back in, and tap the starter. Basically, a field-expedient hydraulic jack. If the engine is in running shape, just loosen the head bolts and start the engine. That's how we loosened up flathead Ford heads rusted tight to 24 studs. Sometimes we had to drive 'em around the block!
Nothing beat experience! I’ll have to apply this if I need to remove the 216’s cylinder head while still installed.
