1 members (Otto Skorzeny),
60
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2021 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 256 | Looking for recommendations on how to dislodge the cylinder head on my 235 that somebody in the past may have used hardening gasket sealer and I don’t have a hoist to yank it off.
For your information all related bolts are off. | | | | | Joined: Mar 2021 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 256 | Forget it I got the cylinder head loose. Used a wood chisel well sharpened and tapped it into the head to block mating surface, no damage to mating surfaces .
Thanks anyway | | | | | Joined: Sep 2009 Posts: 5,909 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 5,909 | Texas - Sometime it just takes posting about a problem to figure out how to resolve it. Glad you got it figured out!
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Feb 2004 Posts: 29,810 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,810 | The easy way is to loosen the head bolts a couple of turns, pour about half a cup of oil into each cylinder, put the spark plugs back in, and tap the starter. Basically, a field-expedient hydraulic jack. If the engine is in running shape, just loosen the head bolts and start the engine. That's how we loosened up flathead Ford heads rusted tight to 24 studs. Sometimes we had to drive 'em around the block! Jerry
| | | | | Joined: Mar 2021 Posts: 256 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 256 | Nothing beat experience! I’ll have to apply this if I need to remove the 216’s cylinder head while still installed. Thanks | | |
