1 members (baldeagle), 158 guests, and 2 robots.
Topics128,110
Posts1,056,241
Members48,437
#1604641 05/27/2026 7:38 PM
52 chevy truck with 250 motor.
I want to go back to a mechanical fuel pump. It was suggested to inspect the cam lobe for excessive wear. I have a pretty good pic for those with more experienced opinions than myself.There is definitely some color difference. If lobe passes inspection I would welcome suggestions on what brand pump may be better than others. Thanks for looking!
1952 5 window 3100
"Learning as I go"
Follow in the DITY
Cam lobe. Just seeing the error. Old eyes, fat fingers, and spell correct can embarrass a man.
1952 5 window 3100
"Learning as I go"
Follow in the DITY
That appears to be a completely normal wear pattern. If you have a way to mount a magnetic base dial indicator, you can measure the lobe lift by turning the engine with the fan blades, with the spark plugs removed. Once you get the lift measured, please post it and I can compare your figure to any of several cams I have on hand, new and used.
Thanks Jerry. Yeah, I don't have one of those. I'll be honest with you, I don't even know what that is. I'm going with "appears to be a completely normal wear pattern" and call it a day. lol. I'm certainly no expert, but nothing is jumping out at me either that looks abnormal. Gonna go pump shopping.
1952 5 window 3100
"Learning as I go"
Follow in the DITY
See if you can find an original pump or a 30 year old replacement pump and rebuild it or have it done.
Virtually all brand new mechanical fuel pumps of all brands for all makes and models are absolute garbage right out of the box. They're all slapped together in China with no concern for any kind of quality control.
Look in the manual for your engine year to see what the fuel pump pressure should be and make sure whatever pump you get meets that spec.
Again, Then and Now Automotive will do a fabulous job rebuilding whatever pump you send them.
1950 Chevrolet 3100 (Ol' Roy)
The fuel pump lobes on the cam are not an aggressive lobe, they don't have much lift. They also don't have much pressure on them, if the old fuel pump arm went bad. it could have scuffed up the lobe, yours looks good enough to run. Apply some grease to the fuel pump arm, not a lot, just something to keep it from running dry till the oil gets to it after starting the engine. The 250 is not as sensitive to fuel pressure as the older engines, I wouldn't worry about fuel pressure, the Mono-jet carbs can hold back pressure pretty good.
I found on my 250 the original fuel line runs up out of the fuel pump and across between the thermostat housing and the valve cover, then turns back towards the carburetor. This made for a really hot fuel line at the cross over point. I made a new line that is straight up out the pump to the top of the valve cover, then up and over to the carburetor. It takes a lot of bends out of the line and keeps it away from the hot thermostat housing.
