4 members (Wally / Montana, Lightholder's Dad, 2-Ton, 1 invisible), 109 guests, and 1 robot.
Topics128,051
Posts1,055,730
#1603481 05/08/2026 8:18 PM
I have put a 1960 235 truck engine in my 41 AK with stock radiator. I am looking for recommendations or suggestions for radiator hoses. Also the a radiator cap
ronsway #1603497 05/08/2026 11:45 PM
AD Addict & Tinkerer
I have a ‘59 235 in my ‘52 and use a 4lb cap. I wouldn’t go any higher with a stock radiator.
Phil
Project Journals
Stovebolt Gallery Forum
ronsway #1603501 05/09/2026 12:23 AM
flex hose for the rad.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
ronsway #1603503 05/09/2026 12:49 AM
Me too. I have a 1941 radiator with a 4lb cap.
1950 Chevrolet 3100 (Ol' Roy)
The inlet and outlet on the 235 are a different size than the radiator. What is the best way to make this work?
ronsway #1603506 05/09/2026 1:06 AM
U
U Offline
I think I got my lower hose from The Filling Station, but everywhere I looked the upper hose was unavailable. So, I ordered a Jeep Wrangler hose from Summit and cut out a straight section for my upper hose. I think I even cut it with a little bend in it. I actually screwed up the first hose by cutting it too short. When I look my second try, maybe I should have cut it another 1/2 inch longer? Oh well, it works.
~ John in Utah
Here We Go
Follow in his DITY Bay
ronsway #1603507 05/09/2026 1:10 AM
U
U Offline
I used the thermostat housing from my old 216.
~ John in Utah
Here We Go
ronsway #1603518 05/09/2026 3:40 AM
Insomniac
Insomniac
Tried a flex hose, but I could not get it to not kink and reduce flow.
Solution in my case was to buy a Gates 20573 molded hose and cut it to fit. Used my band saw with crosscut guide to made a clean straight cut.
Hose catalog
Gord 🇨🇦
1954 1/2 ton 235 4 speed
ronsway #1603523 05/09/2026 11:33 AM
the flex hose i speak of you can stand on and it not kink or collapse. Maybe its not a flex hose.
~ BD.
ronsway #1603524 05/09/2026 12:51 PM
My brother's GTO has the type of hose BD mentions. Gates Vulco-Flex II
ronsway #1603527 05/09/2026 1:40 PM
Go to your local parts store and ask to look at the radiator hose selection. Find one you can cut a section out of, might even find one with different size ends. Be sure to keep the hose number in case you ever need a replacement.
ronsway #1603531 05/09/2026 3:21 PM
Good idea Joe H. Only thing I`d add ,this day and age you better get 2 if it works. Anything that works has a tendency not to be available long.
~ BD.
