0 members (), 132 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#1603394 05/07/2026 8:21 PM
I assumed my 1954 235 had hydraulic lifters. When I set the lifters as per the manual, it won’t start.
I’m second guessing which lifters I actually have and want to double check.
Any differences I can see without taking apart a motor?
Chris
FYI: I’m heavily leaning towards a mechanical/solid lifter due to the year of the motor. I can’t go off of transmission due to potential unknown donor.
ndkid275 #1603406 05/07/2026 11:09 PM
H Online: Content
Get a valve fully closed- - - - -doesn't matter which one- - - - -then apply steady, firm pressure with a pry bar or a long, heavy screwdriver to the pushrod end of the rocker arm. After 2-3 minutes of constant pressure the gap between the rocker tip and the valve stem will increase to 1/8" or more with a hydraulic lifter. A solid lifter will not change gap. The only way a 1954 235 engine would have hydraulic lifters would be a car engine with a Powerglide transmission.
I will try it tomorrow!
I have a 1954 235 that came to me with my project. The stamped serial number next to the distributor indicated that it was assembled to be installed in a car with a Powerglide. As part of the prep for starting the engine, I pulled the side cover so I could see the pushrods and the tops of the lifters. I was able to determine by seeing the tops of the lifters, that they were indeed, hydraulic. (Also, by pulling the side cover, I got a better idea of how clean the motor was internally.)
Nick
1940 KC Model 1/2 Ton Pickup Project
(with '37-'39 Bed and what we think is a '42-'46 Frame)
Taos, New Mexico
Chris - Did we ever decode the serial number from your engine? Post it and we can decode to see at least what it started life as. smile
~ Dan
1951 Chevy 3 window 3100
I will post it shortly!
It’s definitely mechanical lifters! She is adjusted and running beautifully like a singer!
Casting code is G74
Seriel: 0830530F54Z
H Online: Content
"I love it when a plan comes together!"
Chris - The …54Z suffix on the serial number stands for 1954 “Regular” 235 in a passenger car with standard clutch and manual transmission. From the 1954 Chevrolet Data.
Definitely originally a solid lifter engine.
G74 casting date decodes as G = July 7th, 1954.
smile
~ Dan
Thanks GDAD! I learned something new with this engine!
Chris
