5 members (Bill Hanlon, Wickedbass, tclederman, Donf, TexasJim50), 55 guests, and 0 robots.
Topics128,075
Posts1,055,916
Members48,429
#1602508 04/24/2026 5:53 PM
At 70 I find it difficult to put one these Muncie four speeds in by myself so I made this cradle and bolted it to my floor jack. If I had to do several I would have bought a transmission jack but for just one it worked great.
1950 4400
I make plenty of temporary tools and jigs! That looks great!
59 Apache 3100
59 Apache 3100
I did the same & yours looks better than mine. I did the transmission bench press a few times & got tired real quick big_eek
Work smarter not harder ! Great job
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
1950 4400
Thanks man, I tried just using the floor jack but I wound up a quart and a half of gear oil on the shop floor so I made the cradle and it worked perfectly
1950 4400
you should drain the oil out before?
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
