0 members (),
35
robots. Key: Admin ,
Global Mod ,
Mod
Topics128,014
Posts1,055,327
Members48,419
Most Online14,466Apr 26th, 2026
AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
over 30 years! and not clogged down with Ads! Again, thanks!
At 70 I find it difficult to put one these Muncie four speeds in by myself so I made this cradle and bolted it to my floor jack. If I had to do several I would have bought a transmission jack but for just one it worked great.
1950 4400
I make plenty of temporary tools and jigs! That looks great!
59 Apache 3100
59 Apache 3100
I did the same & yours looks better than mine. I did the transmission bench press a few times & got tired real quick
Work smarter not harder ! Great job
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
1950 4400
Thanks man, I tried just using the floor jack but I wound up a quart and a half of gear oil on the shop floor so I made the cradle and it worked perfectly
1950 4400
you should drain the oil out before?
~ BD."You won't find me in an old folks home" Pioneer Florida Cracker 1958 Apache Stepside 1958 Apache 1/2 ton Panel 1959 Apache 1/2 ton Panel
