| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Last week I posted that after I got my 53 3100 out of storage it wouldn't start & the horn wouldn't work. I determined that the starter was shot but the horn had me stumped. Both horns worked when I powered them directly & the relay tested fine. I assumed it was wiring in the steering column & deferred further work while my truck was up on jack stands.
Today I installed the rebuilt starter. The truck started right up and the horns worked! Please help me understand that. Thanks
~Denny 1953 Chevy 3100 w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter In the Gallery Forum1998 Chevy Suburban 350 ci awd/4wd | | | | | Joined: Feb 2004 Posts: 29,747 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,747 | The power wire to the dash taps off the battery cable connector at the starter. Chances are you might have had a loose or dirty connection there that was starving the horn, headlights, ignition switch, etc. for voltage. Jerry
| | | | | Joined: Nov 2014 Posts: 164 'Bolter | | 'Bolter Joined: Nov 2014 Posts: 164 | Maybe, but the headlights, dash lights & dome light were strong. Plus I thoroughly cleaned the connections when I was trouble shooting the starter. ???
