| | | Forums66 Topics128,036 Posts1,055,461 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 50 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 50 | Have all information Thank you
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy 52-Mobil,If the 261 came from a standard four speed truck the bellhousing from the 216 should fit and work. As far as I am aware there was only one year of 261 production 54 which used a six volt fly wheel, so chances are your 261 will have a 12 volt flywheel which will require a 12 volt starter. You can always compare the two engines components to check for differences, hope that helps. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The flywheel, clutch, starter, and bellhousing from the 216 should be able to bolt onto the 261 block and crankshaft. The 1946 transmission- - - -is it a 3 or 4 speed? There was a major change in transmission design in around 1947/48, with a different bellhousing bolt pattern on the later transmissions. The earlier, lighter duty trans and clutch might be on the ragged edge, torque-wise, for handling the output of the 261, so don't abuse the light duty driveline components. Jerry
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | When we did my 216 - 261 conversion Read about it here, we just moved the ring gear from the 216 flywheel to the 261's flywheel. We flipped the gear around while we did it to put the unworn side of the teeth to the starter gear. Swapping the ring gear was pretty simple. Why didn't we just use the 261 flywheel as is? I don't remember.... maybe I talk about it in the writeup. Or better yet, maybe Jerry remembers -- he was there guiding us through the whole thing. IF you are fortunate to find a 261 out of the 1954 mold (again, see the article...), its a FAR simpler swap than the later 261's. Either way, make sure you know what year your block is so you get things right (like main bearings). Knowing the Date Code is critical, not just the casting code as not all 261's are identical and you want to know exactly what you have before you starting buying expensive parts for it  How do I know this? Indeed .... read the article
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2020 Posts: 79 'Bolter | | 'Bolter Joined: Feb 2020 Posts: 79 | Like HRL said swap the ring gear and everything else works. If you looking to upgrade the old crash box. I used a bell housing with the casting #3835201. It has the pin for the pedals plus it has the larger pilot hole and bolt pattern for a "newer" style transmissions. It was originally used for 49-53 truck bell housing.
51 GMC 100 with 59 chevy 261 under the hood. 3 on the floor with 3.42 gear.
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | John, IIRC, I was not present for the 216/261 swap. I got concerned about low oil pressure on a ride-along at a later date, and some further investigation revealed some badly worn connecting rod bearings. Then I got to participate in the rebuild of the 261. Jerry
| | | | | Joined: Dec 2025 Posts: 12 'Bolter | | 'Bolter Joined: Dec 2025 Posts: 12 | Most likely, the 216 flywheel ring gear was used due to compatibility with the original 6V starter. When we did my 216 - 261 conversion Read about it here, we just moved the ring gear from the 216 flywheel to the 261's flywheel. We flipped the gear around while we did it to put the unworn side of the teeth to the starter gear. Swapping the ring gear was pretty simple. Why didn't we just use the 261 flywheel as is? I don't remember.... maybe I talk about it in the writeup. Or better yet, maybe Jerry remembers -- he was there guiding us through the whole thing. IF you are fortunate to find a 261 out of the 1954 mold (again, see the article...), its a FAR simpler swap than the later 261's. Either way, make sure you know what year your block is so you get things right (like main bearings). Knowing the Date Code is critical, not just the casting code as not all 261's are identical and you want to know exactly what you have before you starting buying expensive parts for it  How do I know this? Indeed .... read the article  | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | That's correct- - - - -John's 3800 pickup ("Charlie") still runs a 6V electrical system. Jerry
| | | | | Joined: Nov 1995 Posts: 5,715 62401 | | 62401 Joined: Nov 1995 Posts: 5,715 | That's right!! I remembered that later after I had posted that.
