3 members (Gib70, Leo, Gray_Ghost), 66 guests, and 3 robots.
Topics128,134
Posts1,056,410
Members48,441
This video is 16 minutes long. You’ll see me assemble a non-world class T5 transmission. I made it for people who enjoy watching informative videos for the sake of education. It is not meant to be an instructional video.
VIDEO LINK
I watched it. Excellent work.
YouTube actually lacked a decent, complete rebuild of a NWC T5.
1951 3100
Hey Lugnutz - I’m gonna have to tackle this job myself soon….inspect/rebuild of a NWC S10 T5. It will certainly need the input shaft swap, not sure if it needs a full rebuild or now.
Anyway, it looks in the video like you did the entire assembly of the tranny WITHOUT using a hydraulic shop press. Is the press needed for the ~disassembly~ phase on a full rebuild?
1951 3100
Originally Posted by JW51
Hey Lugnutz - Is the [a shop] press needed for the ~disassembly~ phase on a full rebuild?
The short answer is yes. You need a shop press to carefully
1. remove the countershaft from the case.
2. remove the 3/4 slider hub
3. remove 5th and 1st gear together with the bearing between them.
4. Front countershaft bearing from the case and the rear countershaft bearing from the countershaft.
I wrote a DIY showing every step. LINK HERE
59 Apache 3100
59 Apache 3100
Fantastic Video, not to nitpick but the information was interesting enough that the background music was not needed.
chug
1959 3100, original 235/3 on the tree w/overdrive. Carter YF 2100S carb, 205/75/15 w/front sway bar
