6 members (farmallb, ChevyBlue, 2-Ton, carbking, Hotrod Lincoln, tclederman), 144 guests, and 1 robot.
Topics128,089
Posts1,055,991
Members48,430
#1601461 04/08/2026 8:53 PM
My horn was dead when I took my truck out of storage and I need some help troubleshooting the problem. I converted my '53 3100 to 12v many years ago but I've continued to use the original 6v horns. They really sound off!
I picked up some tips from a recent thread by bucktruck. I've tested the horns by applying power directly to them and they both work fine. I see that 51 Jimmy jumped in and reported that he got his horn to honk by running a wire directly from the "S" post of his relay to the horn. That didn't work for me. Is that how I rule out a problem with that relay? If not, how do I? What else should I check before I pull the wheel?
Otto talked about a connector about 2/3 of the way up the steering column. I've never pulled my wheel but I guess I'll have to if that's where this issue leads me. Thanks for any tips!
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
You can find the connection without pulling the wheel. Look under there and you'll see the wire from the horn button coming out of a slot in the steering column.
1950 Chevrolet 3100 (Ol' Roy)
Denny,
I've been using 6v clamshell horns on my 12v system for many years, then back around November of last year, the horns suddenly stopped. I tested my horn relay and found no voltage coming out of the exit side, so I replaced the horn relay with a NAPA #HR101SB. TOOT! TOOT! Just something to consider.
Craig
