4 members (Jon G, Gray_Ghost, Bill Hanlon, MRMEROTH11), 85 guests, and 0 robots.
Topics128,068
Posts1,055,881
Members48,428
Howdy. 1959 1/2 ton. Just installed my SBC and am using stock type front and rear mounting hardware. I cannot find in the manual any torque specs for the stock front mounts. Obviously as I tighten the nuts, top and bottom, it will compress the rubber biscuits (an old Jake and Elwood Blues Brothers song....Ha). Any ideas? Maybe just use Nylock nuts and snug em real good??
Id use lock washers and tighten within reason. Drive it and tighten again if need be.
~ BD.
1958 Apache Stepside
1958 Apache 1/2 ton Panel
1959 Apache 1/2 ton Panel
7
7 Offline
The bird legs mount are not very heavy diameter, they might be ok at 50 ft./lbs or so.
The 1957 Chevy Shop Manual (no changes noted in the 1959 Supplement) just says to "install the nuts and tighten securely". Definitely not a bad idea to recheck and tighten after driving as Guitplayer suggests above. wink
~ Dan
1951 Chevy 3 window 3100
Your front engine mounts should assemble in this order on each end of the stud:
Stud
Large Flat Washed
Large Rubber Cushion
Cupped Washer
Mount Bracket
Small Rubber Cushion
Small Flat Washer
Lock Washer
Nut
The nut should be tightened until the Small Flat Washer is tight against the stud shoulder and torqued to 30 ft lb (normal 3/8" bolt/nut torque spec).
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
