4 members (Gray_Ghost, BillCollins, Still At It, 1 invisible), 134 guests, and 2 robots.
Topics128,078
Posts1,056,054
Members48,433
#1601012 04/01/2026 8:06 PM
TeW
Offline
I need some advice. I installed a new wire harness. everything seems to be ok except the horn. The horn works when the engine is not running, when the engine is running the horn does not work. Any ideas?
TeW #1601020 04/01/2026 10:22 PM
1st question ...
Is the 'new wiring harness' an exact reproduction of a 37 GMC wiring harness?
TeW #1601025 04/01/2026 11:54 PM
TeW
Offline
little more back ground...with my 37 GMC 1/2-ton truck i changed out the motor and trans to a 1946 chevy 216.5 engine and 3 speed. The harness I bought was from Classic Parts USA. The part# 52-015, (1934-39) Wiring Harness-for a Generator. I also installed a voltage regulator. The harness instructions were somewhat limited. I found a drawing online.
TeW #1601030 04/02/2026 12:30 AM
Please point me to the drawing you found online. The one Classic Parts has for sale on their website says GENERIC DRAWING FOR WEBSITE ONLY and certainly isn't for a 36 Chevy Truck unless it had a V8 engine. Also has way too many circuits.
