6 members (Nick in Manitou, DBJ71SuperCustom, jay d, spanky, 54farmtruck, Woogeroo), 67 guests, and 2 robots.
Topics128,231
Posts1,057,809
Members48,477
back yard wrench turner
I've been unable to find a set of aftermarket gauges that will fit my '38 without cutting the dashboard.
Has someone here located a set?
I would like to have a GPS speedometer also.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
There is an old Datsuns car set that fit right in the openings, I don't remember what year they were, but 25 years ago they were getting hard to find used. Look here at Speed Hut , https://speedhut.com/gauge-accessor...edometer-tach-temp-fuel-volts-oil-clock/ I don't know right off hand what the stock gauge diameters are, but SpeedHut may have something that will fit if you look around. I use their Air/Fuel ratio gauge, it high quality and customer service is excellent. .
I used the search here on the Stovebolt site, the above Datsun 240Z gauges are the correct ones, the factory chrome rings should fit also.
What size hole?
Originally Posted by MNSmith
What size hole?
Mark, it's close to 4 1/4 without taking it apart for a more accurate measurement.
There are only 3 holes, the center is speedo, and the 2 smaller sides are fuel, water temp, oil pressure and ampmeter.
Wayne
1989 Silverado
Autometer makes a 3 1/2" gauge. You would have to make an adapter ring. I did the same for my Speed Hut speedo.
That would work. I don't think I'm that talented though. smile
Wayne
1989 Silverado
Yeah - how do you just “make” an adaptor ring that nice?😁
Brendan
1940 Chevrolet 1/2-Ton Pickup
Restoring Dad's old truck
I went with GPS speedometer on my 53. It's simple and effective. I went with DD gauges. They also Bluetooth to my phone. That's nice when working under the hood. I have a Frankland Quick Change rear end with 128 possible gear ratios so it was a no brainer for me. It also gives me 0-60, 1/8 mile and 1/4 mile times. It updates something like 100 times a second and has memory for loss of signal. GPS is the way to go. It also powers my cruize control.
