| | | Forums66 Topics128,081 Posts1,056,073 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | I have oil leaking at the base of my distributor shaft where it goes into the block. Only leaks when engine is running. Dipstick measures full. Is there a seal that needs replacing and how hard of a job is it? Thanks! ray durham | | | | | Joined: Mar 2014 Posts: 4,489 Moderator, Electrical Bay | | Moderator, Electrical Bay Joined: Mar 2014 Posts: 4,489 | Stock distributor, Ray? Some of the HEI distributors will leak there. They need an O ring but normally the stock distributors don't although I've seen some which had a rather thin flat ring gasket between the distributor flange and the block. What year is your engine?
~ Jon 1952 1/2 ton with 1959 235 | T5 with 3.07 rear end
| | | | | Joined: Feb 2004 Posts: 29,794 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,794 | Original equipment type stovebolt distributor housings that move when the vacuum advance operates "mark their territory"- - - - -and there's virtually nothing that can be done to prevent it. Installing a PCV system instead of a road draft tube keeps a slight vacuum on the crankcase, and will minimize the leak, bit it might not totally eliminate it. Jerry
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | That is how the distributor housing gets lubricated, With all of the motion that goes on from the vacuum advance moving the housing, no oil there would wear out the housing or the block or both.
| | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | | | | | | Joined: Aug 2016 Posts: 121 'Bolter | | 'Bolter Joined: Aug 2016 Posts: 121 | | | |
