5 members (BC59, gswbbc, Steelonsteel, Otto Skorzeny, Cosmo), 92 guests, and 3 robots.
Topics128,031
Posts1,055,434
Members48,422
#1600594 03/26/2026 9:38 PM
I have oil leaking at the base of my distributor shaft where it goes into the block. Only leaks when engine is running. Dipstick measures full. Is there a seal that needs replacing and how hard of a job is it?
Thanks! ray durham
bucktruck #1600597 03/26/2026 11:22 PM
Moderator, Electrical Bay
Stock distributor, Ray? Some of the HEI distributors will leak there. They need an O ring but normally the stock distributors don't although I've seen some which had a rather thin flat ring gasket between the distributor flange and the block. What year is your engine?
~ Jon
Original equipment type stovebolt distributor housings that move when the vacuum advance operates "mark their territory"- - - - -and there's virtually nothing that can be done to prevent it. Installing a PCV system instead of a road draft tube keeps a slight vacuum on the crankcase, and will minimize the leak, bit it might not totally eliminate it.
That is how the distributor housing gets lubricated,
With all of the motion that goes on from the vacuum advance moving the housing, no oil there would wear out the housing or the block or both.
Jon G #1600623 03/27/2026 12:03 PM
1959 engine without HEI
Thanks Jerry
