7 members (mick53, Shaffer's1950, klhansen, TooMany2count, Peggy M, Hotrod Lincoln, 1 invisible), 73 guests, and 2 robots.
Topics128,132
Posts1,056,388
Members48,441
#1600187 03/20/2026 10:06 PM
Wondering about opinions as to a value on this 1940 GMC. Assume no motor or tranny. Pretty rough but mostly there. I’m thinking parts only.
Brendan
1940 Chevrolet 1/2-Ton Pickup
Restoring Dad's old truck
Brendan - Not to open a can of worms here, but the answer is basically whatever you're willing to pay (or whoever may be the prospective buyer). Here's a related topic Tech Tip that provides details and previous "Stovebolt" wisdom that you can apply to your question. wink
BTW - Here's the link to the original ad for the 1940 GMC. Several more pictures in the full ad as well as the asking price from the seller.
~ Dan
1951 Chevy 3 window 3100
DadsFirstPickup #1600253 03/22/2026 12:23 AM
Former Workshop Owner
Does it have a title? That will affect the value.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
DadsFirstPickup #1600255 03/22/2026 12:32 AM
Looks like you are close to the area might be worth it to feel it out .
1954 Canadian GMC 9300
"The Journey"
Follow in the DITY
To be honest I was only thinking of parts that also fit the 40 Chevy. I need to research a bit to find what is interchangeable but the option is there to part out the rest for others. Therefore I feel the asking price is more than I like. Was hoping for a reason to brow beat the fella. I am close enough to go look and will do so in the near future.
Brendan
J Lucas #1600288 03/22/2026 7:34 PM
No title John. It does have a motor and tranny in it. It is a 3/4 ton. I was hoping to rob some park brake parts out of the rear wheels for my 40 half ton but would need some assistance with that cross reference.
Brendan
Brendan - A quick check in the Chevrolet Master Parts Books shows the 1940 Chevrolet 1/2 ton (KC) and 3/4 ton w/11" rear brakes (KD) shared the same rear axle parking brake components. The 1940 3/4ton "Special" (Heavy Duty) pickup model KE w/14" rear brakes shares the Huck parking brake parts with 1937-52 1 Ton models, so not the same.
1940 GMC 1/2ton (Model AC100) and 3/4 ton (Model AC150) shows both used the same parking brake pieces in each truck too in the GMC Master Parts Books I have.
One step further - I compared the GM part numbers in the Master Parts Books for both Chevy and GMC and 1940 Chevrolet 1/2 & 3/4 ton pickups and the same sized 1940 GMC pickups are the same. *(See the list below I posted previously in a Swap Meet listing which I've added the GMC Parts Group#s to)
So yes, they will fit your truck! thumbs_up
Chevy/GMC Parts Group - Description - Part# - Qty **
5.149/4-88 - Lever parking brake shoe 8" OL - Left GM# 475477 - 1 each
5.149/4-88 - Lever parking brake shoe 8" OL - Right GM# 475468 - 1 each
5.150/4-88 - Extension-strut, parking brake shoe lever 7-1/16" OL - GM# 475481 - 1 each
5.150/4-88 - Extension-strut, parking brake shoe lever 7-1/16" OL - GM# 475482 - 1 each
5.151/4-88 - Spring, parking brake shoe lever extension 15/32" ID x 1-3/8" OL - GM# 476104 - 2 each
5.158/4-88 - Bolt, hex head 3/8" - 24 x 15/16" w/eccentric - GM# 475492 - 2 each
8.917/4-88 - Nut, hex head 3/8" x 24 - GM# 120369 - 2 each
8.932/4-88 - Lock washer, internal tooth 3/8" - GM# 138557 - 2 each
**Added GMC parts Group #s after the Chevy #s - The GMC info is taken from GMC Master Parts Book X-145001 dated 7-5-1945 with changes 1-5, and Supplement X-145020 dated 12-1-1945.
PS - If they are still there, the clips between the parking brake cable ends and lever will fit too!
~ Dan
Thank you sir.
Brendan
