2 members (2 invisible),
72
Mod | | | Forums66 Topics128,208 Posts1,057,443 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2016 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 13 | Does anyone have a source for a speedo cable for T5 to a stock mechanical gauge in my 54 Chevy truck?
Last edited by Gdads51; 03/17/2026 12:34 AM. Reason: edit to move into its own thread
| | | | | Joined: Sep 2009 Posts: 6,049 Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT | | Gearhead, Stovebolt Tech and Parts Tracker, Mod for Swap Meet and GTT Joined: Sep 2009 Posts: 6,049 | Mike - Need more info on what T5 transmission you have. Does it have the standard mechanical speedo drive or the later electronic sensor unit?
~ Dan 1951 Chevy 3 window 3100Follow this story in the DITY Gallery"My Grandpa Carl's Truck and How it Became Mine"1966 Chevelle (Wife's Hot Rod) | 2013 Chevy Silverado (Current daily driver) US Army MSG Retired (1977-1998) | Com Fac Maint Lead Tech Retired (1998-2021)
| | | | | Joined: Apr 2016 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 13 | Clarification on my T5 original question.
Does anyone have a source for an electronic speedo cable for T5 to a stock mechanical gauge in my 216, 52 Chevy truck? SP5 US Army, 1968-1971.
Last edited by Gdads51; 03/18/2026 11:17 PM. Reason: minor edit to merge with existing same topic thread
| | | | | Joined: Mar 2021 Posts: 430 'Bolter | | 'Bolter Joined: Mar 2021 Posts: 430 | going from a electronic output to a mechanical one requires a converter with a motor etc. Search up Speedhut Speedbox and you will have several options. not going to be cheap. I would also look around at review.s It works and works well for most. Some folks complain of the sound when mounted under dash etc. Other option is restomod dash that takes electronic or gps feeds. | | | | | Joined: Jul 2014 Posts: 362 'Bolter | | 'Bolter Joined: Jul 2014 Posts: 362 | Another option would be to swap on a tail housing from a mechanical speedometer S10 T5, and swap the gear on the output shaft, then add the drive gear, driven gear and bullet required to spin the cable. At one point there was someone on eBay either selling the tail housing, or selling the service of machining the electronic tail housing for mechanical speedometer use. | | | | | Joined: Apr 2016 Posts: 13 'Bolter | | 'Bolter Joined: Apr 2016 Posts: 13 | Thank you all for that info. Hope to figure out which way I want to go to hook up this configuration!! | | |
