2 members (Otto Skorzeny, Johnny N), 82 guests, and 0 robots.
Topics128,076
Posts1,055,924
Members48,430
#159888 10/05/2007 11:55 PM
I picked up an old blow torch from an estate sale the other day. What do these things burn?
#159889 10/06/2007 2:33 AM
I've got one I haven't fired up yet, butt.. I remember they were also called a Kerosene torch. You should be able to use Kerosene, camp stove fuel, Diesel. I've got some camp stove fuel I should fire mine up. Is there any particular use for these old torches that be be done with any other torch?
Larry
I don't own a vehicle that isn't old enough to drink.
#159890 10/06/2007 2:56 AM
GreenGMC,
I think they will work fine on White Gas, which is more commonly known as lantern fuel....the stuff you put in your Coleman lantern.
I can almost swear to this...I think they will work well on plain old gasoline too. It sounds real creepy to have a little tank full of gas under a blazing torch, but I remember helping my friends father replace linoleum tiles, and we heated them with this torch prior to cutting and installing them.
Stuart
#159891 10/06/2007 3:00 AM
Be careful when you fire it up. My brother got one and when he tried it gasoline squirted about 20 feet. Apparently the orifice is bad. Fun to play with but no good for work.
#159892 10/06/2007 5:06 AM
I agree with Cletis...fun to play with. With all of the propane, MAPP gas and Turbo Torches out there, the old blow torch would only be a novelty.
Stuart
#159893 10/06/2007 5:36 PM
I agree with all .
I think for safety sake ....clean er up an put it in the shop somewheres for a conversation pc.
I wouldnt try to light it ...lol
Tim
1952 Chevy Shortbed
Photos in Photobucket
#159894 10/07/2007 4:53 AM
Former Workshop Owner
I have an old one from my dad, he always used white gas (Coleman fuel) in it. I have never tried to light it, but if I do, that's what I will use.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
#159895 10/09/2007 3:38 AM
Apprentice
Apprentice
Actually those old blow torches work very well for what they were designed for.They do have to be in useable condition and you need to know how to operate them.I use plain gasoline in mine and it works very well.There is a small cup on the top of the tank that you fill with a small amount of gas and light.This heats the generator in order to vaporize the fuel.When the cup is about to burn out you open the fuel valve and should have a nice blue flame.Most torches have some sort of a hook on top.This is to hold a soldering iron in the flame.Works very well for soldering sheet metal.I've also used them to melt small amounts of babbit for bearings.I probably wouldn't use one in my living room but they are no more dangerous than many other tools in the shop if used improperly. Chip Watford
#159896 10/16/2007 6:56 PM
They were used by plumbers and other water men to melt lead into joints on cast iron pipe. in ditches as well as crawl spaces in buildings. they work similar to a Coleman lantern or camp stove. with a air pump and a need to be hot before they work well. they can shoot a very long flame. be care full.
"It ain't a truck if you can't hose out the cab."
#159897 10/17/2007 1:35 PM
Kinda fun to use, white gas(naptha) is best but regular gasoline will work.
#159898 10/18/2007 4:34 AM
I have two of them, and I think they are a very handy tool. I don't think they are any more dangerous than any other tool that produces concentrated fire.
When you run out of fuel, I normally use Coleman white gas, but you can fill it up with whatever is handy. I have often used kerosene.
If you are doing a big job, it is much handier and much less expensive than the small butane bottles on the Burnzomatic.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
#159899 10/20/2007 3:08 PM
I
Apprentice
Apprentice
I Offline
I agree with Chester. I have one that my grandfather used in plumbing cast iron waste pipe. He heated lead with it to solder the joints together.
Moderated by  MNSmith
