4 members (Pete1946, Gib70, Woodcmiami, Bill Hanlon), 100 guests, and 3 robots.
Topics128,090
Posts1,056,371
Members48,442
#1598643 02/26/2026 5:17 PM
B Online: Content
I finally gathered all the parts to convert the really hard to use (for an overweight 79 year old) spare tire mechanism of my '52 GMC 3/4 flatbed.
Years ago I had mounted a trailer hitch receiver which bolted to the rear crossmember of the truck. A neighbor welded a piece of 1/4" flat plate on top of the receiver mount after I had drilled 4 mounting holes for the hoist, which was from a 1998-2004 F150. The reason I used this hoist is that it mounts on a horizontal surface with the cable coming out of the bottom. I mounted the hoist with the joint for the handle turned about 15 degrees counter clockwise from straight back so the handle would not hit the backup light I have on the back of my flatbed.
I bought a spare tire tool kit for a 2004-18 F150 that consisted of the tools necessary to raise my jack and my new hoist. I had to flatten (used a BFH) the male end of one of the pieces from square to slightly rectangular to fit the hoist.
Once everything was installed I found that the handle wanted to flop around when operated, so I drilled a hole in the bottom rear of the flatbed and mounted a 1/2" eye bolt to support the hoist handle while cranking up/down.
When hoisted, the spare tire pulls up against 2 small crossmembers that the original spare mechanism pushed the spare up against.
The hoist and the tool kit were under $50 total from Amazon.
Pictures below.
U
U Offline
Nicely done Bill. You reminded me that I need to find a bottle jack and tools in case I get a flat.
~ John in Utah
Here We Go
Follow in his DITY Bay
Former Workshop Owner
Nice job. 👍
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
Nice work Bill. thumbs_up
I'd be a little concerned about your truck getting a case of hives with those Ferd parts onboard. wink
B Online: Content
I couldn't find a GM hoist that mounted on top of a horizontal surface, so I put a bottle of anti-Ferd vaccine in the gas tank and am hoping for the best.
Moderator
Moderator
2 Offline
I like it and have a doner 1981 F-150 that may have that same hoist?
Thanks for the tip!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I think it will survive. wink
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
